Hi list,
Does somebody know how to import vmap1 data in GRASS?
Jaime
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
Regístrate ya - http://correo.espanol.yahoo.com/
Hi list,
Jaime
Correo Yahoo!
Le Lundi 19 Février 2007 14:10, Jaime Carrera a écrit :
Hi list,
Jaime
First of all, you need to install gdal with the OGDI format support (not build
by default), so you probably need to build your own gdal-ogr command.
Then you can run :
ogr2ogr contourl.shp gltp:/vrf/mnt/data/v0eur/vmaplv0/eurnasia
“contourl@elev(*)_line”
to convert vmap to shapefile. Avoid to mix upper and lower case in your path !
Then you can import them into GRASS.
Y.
Yves Jacolin
http://yjacolin.gloobe.org
Hi list,
Jaime
First of all, you need to install gdal with the OGDI format support (not build by default), so you probably need to build your own gdal-ogr command.
Then you can run :
ogr2ogr contourl.shp gltp:/vrf/mnt/data/v0eur/vmaplv0/eurnasia “contourl@elev(*)_line”to convert vmap to shapefile. Avoid to mix upper and lower case in your path !
Also see Markus' article on VMAP0 in the GRASS newsletter Nr. 3:
http://grass.itc.it/newsletter/grassnews3.html
Moritz
ma, 2007-02-19 kello 15:02 +0100, Moritz Lennert kirjoitti:
>> Hi list,
>> Thanks,
>> Jaime
> Hi,
> Then you can run :
> Then you can import them into GRASS.Also see Markus' article on VMAP0 in the GRASS newsletter Nr. 3:
http://grass.itc.it/newsletter/grassnews3.htmlMoritz
Especially helpful is to notice, that the path name to your vmap0
directories should not contain UPPERCASE letters not any special
characters, \$_ and the like.
Harri K.
Yves Jacolin wrote on 02/19/2007 02:34 PM:
Hi list,
Jaime
Then you can run :
An (untested) alternative might be to get the FWtools which ship with OGDI driver
and convert to SHAPE or whatever there. Then v.in.ogr to import.
http://fwtools.maptools.org/
