Respected Friends,
Could you please guide me how to find this layer?
**transmissivity_singleway**=*name* **[required]**Name of the single-way atmospheric transmissivitymap [-]
**temperaturedifference2m**=*name* **[required]**Name of the difference map of temperature from surface skin to about 2 m height [K]
i have Landsat 8 and meteorological data from the station(temp max, min).
Mr Yann Chemin explained for me but i did not understand.
it will be so helpful if any one can explain how to get these layers to be able to calculate the ET in GRASS…
Regards
hindo kush wrote
Respected Friends,
*transmissivity_singleway*=*name* *[required]*Name of the single-way
*temperaturedifference2m*=*name* *[required]*Name of the difference map of
able to calculate the ET in GRASS...
Regards
grass-user mailing list
grass-user@.osgeo
Which GRASS module do you want to use?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
Dear Helmut,
The version i use currently is winGRASS 7.4. 0
Thanks
On Mon, May 28, 2018 at 6:27 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
hindo kush wrote
Respected Friends,
transmissivity_singleway=name *[required]*Name of the single-way
temperaturedifference2m=name *[required]*Name of the difference map of
Regards
grass-user@.osgeo
best regards
Helmut
grass-user@lists.osgeo.org
I asked for the module you want to use?
best regards
Helmut
Dear Helmut,
i wana use the i.evapo.mh. and i.eb.eta or actual evapotranspiration module.
Regards
best regards
Helmut
Hi
Have you followed the tutorial available in this link prepared by Yann:
https://trac.osgeo.org/grass/browser/grass-promo/tutorials/grass_landsat_ETa
Also attached the pdf with this email.
It gives you an overall picture on how to use ET modules in GRASS GIS to estimate actual ET.
Please give it a try and ask questions you may have.
There is an external Python script using GRASS lib, applying SEBAL on Landsat data (never tried !!)
https://github.com/wwolff7/SEBAL_GRASS/blob/master/Sebal70.py
Regards
Sajid
On Tue, May 29, 2018 at 8:08 AM, hindo kush <hindokush12@gmail.com> wrote:
Dear Helmut,
Regards
best regards
Helmut
