[GRASS-user] Incorrect x and y shift values for Alaska State Plane Zone 1 (omerc)
Hello List,
While I am old to GIS, I am very new to the GRASS world.
I am running GRASS 6.4.3C2 for Windows and have added a raster DEM (GeoTIFF)
map layer. The DEM originated from ArcGIS with the projection defined as:
/Projection: Hotine_Oblique_Mercator_Azimuth_Natural_Origin
False_Easting: 5000000.000000
False_Northing: -5000000.000000
Scale_Factor: 0.999900
Azimuth: -36.869898
Longitude_Of_Center: -133.666667
Latitude_Of_Center: 57.000000
Linear Unit: Meter (1.000000)
Geographic Coordinate System: GCS_North_American_1983
Angular Unit: Degree (0.017453292519943295)
Prime Meridian: Greenwich (0.000000000000000000)
Datum: D_North_American_1983
  Spheroid: GRS_1980
    Semimajor Axis: 6378137.000000000000000000
    Semiminor Axis: 6356752.314140356100000000
    Inverse Flattening: 298.257222101000020000/
This should be equivalent to EPSG 26931, or in PROJ4 lingo:
+proj=omerc +lat_0=57 +lonc=-133.6666666666667 +alpha=323.1301023611111
+k=0.9999 +x_0=5000000 +y_0=-5000000 +ellps=GRS80 +datum=NAD83 +units=m
+no_defs
What puzzles me, is that in GRASS, *g.proj -p* for the layer returns:
-PROJ_INFO-------------------------------------------------
proj : omerc
datum : nad83
ellps : grs80
lat_0 : 57
lonc : -133.6666666666667
alpha : 323.1301023611111
k : 0.9999
x_0 : 0
y_0 : 0
gamma : 323.1301023611111
no_defs : defined
The values for x_0 and y_0 are zero instead of 5000000 and -5000000.
Can anyone explain to me what is happening here? Is this a bug? If not, how
do I get GRASS to define the projection correctly?
Thank you for any help,
Frances
View this message in context: http://osgeo-org.1560.n6.nabble.com/Incorrect-x-and-y-shift-values-for-Alaska-State-Plane-Zone-1-omerc-tp5026832.html
