[GRASS-user] increase performance of i.ortho.photo/i.photo.rectify
I am orthorectifying 3 channel aerial photographs using i.ortho.photo (GRASS 6.4.1, Ubuntu 10.04 64bit, dual core (each 3 GHz), 4 GB RAM).
I'm new to GRASS so no clue whether it's possible to make the rectification process to use the computer's resources better. i.photo.rectify is using at most 30% CPU, processing of one channel takes about 15-20 minutes. I suppose it would be much faster if it would use one core running at 100%.
Is there an optimal amount of memory that should be assigned to the process or the more the better?
Any suggestions would be more than welcome!
Andras
On Thu, May 26, 2011 at 12:37 PM, Andras Balazs <andras.balazs@metla.fi> wrote:
i.photo.rectify has been overhauled only recently for 6.4.2: the
module is now faster and the results are more accurate. If possible,
upgrade to GRASS 6.4.2. With regard to memory, yes, the more the
better.
Markus M
