I’m running r.neighbors for a global 250m raster with window-size setting larger than 100 pixels.
The computation take almost 1 week and i’m thinking if there is a way to speed up the process.
I know how to set-up a multi-region & multi-core computation and working in tiles but I would avoid due to the difference that I would encounter in the tile borders (and tile overlap will be required).
Is it possible to run r.neighbors in parallel or increase the memory that r.neighbors would use (as developed in r.watershed)?
Thank you
Best
Giuseppe
Giuseppe Amatulli, Ph.D.
Research scientist at
Yale School of Forestry & Environmental Studies
Yale Center for Research Computing
Center for Science and Social Science Information
New Haven, 06511
Teaching: http://spatial-ecology.org
Work: https://environment.yale.edu/profile/giuseppe-amatulli/
