[GRASS-user] Indentify cell with maximum value per category of a cover map
I’d like to identify the cell of maximum flow accumulation for each subbasin.
For example, I have a cover raster map representing all my subbasins (each subbasin has its own cat value). Additionally, I have a flow accumulation map. Now, I’d like to get a map with cells that are actually those with the largest flow accumulation per subbasin (all other cell should be NULL). I guess, using r.stats.zonal/r.statistics I can identify the maximum flow accumulation value for each subbasin, but this doesn’t provide me a map with the corresponding cells!? Is there a straight forward way to do that in GRASS with e.g. the mapcalc? Or do I need to loop over each subbasin?
Any suggestions?
cheers,
Johannes
On 17/05/17 12:07, Johannes Radinger wrote:
I'd like to identify the cell of maximum flow accumulation for each
subbasin.
accumulation map. Now, I'd like to get a map with cells that are
this doesn't provide me a map with the corresponding cells!? Is there a
Somthing like this might work:
r.stats.zonal cover=bassins base=accumulation output=maxval
r.mapcalc maxpixels = "if(accumulation < maxval+epsilon && accumulation > maxval - epsilon, 1, null())
The use of an epsilon value is to avoid difficulties of determining floating point number equalities.
Moritz
