I tried to create a bufferzone (inner and outer area) around an area boundary
using following steps (reproduced with spearfish quads data):
# change boundary to line
v.type input=quads output=quadsline type=boundary,line
# remove centroids from line map
v.edit map=quadsline type=centroid tool=delete cat=1-3
v.build quadsline
Erzeuge Topologie ...
3 primitives registriert
Building areas: 100%
0 Flächen erstellt
0 Inselflächen erstellt
Füge Inselflächen hinzu:
Füge Zentroide hinzu: 100%
Die Topologie wurde erstellt.
Anzahl von Knoten : 2
Anzahl von Primitives : 3
Anzahl von Punkten : 0
Anzahl von Linien : 3
Anzahl von Boundaries : 0
Anzahl von Zentroiden : 0
Anzahl von Flächen : 0
Anzahl von Inseln : 0
Now I tried to buffer the lines, but v.buffer does not recognise there are
lines (and not boundaries) available in the quadslines file:
v.buffer in=quadsline out=quadsbuffer buffer=1000
Toleranz in Karteneinheiten: 10
Lines buffers...
100%
Areas buffers...
Building parts of topology...
0 primitives registriert
Anzahl von Knoten : 0
Anzahl von Primitives : 0
Anzahl von Linien : 0
Anzahl von Flächen : -
Anzahl von Inseln : -
Is this a bug or do I need another step, so v.buffer finds the existing lines
and buffers correctly? When I export the quadslines to a line shape and import
again, v.buffer works as expected.
v.build quadsline
0 Flächen erstellt
v.buffer in=quadsline out=quadsbuffer buffer=1000 Toleranz in Karteneinheiten: 10
Lines buffers...
100%
Areas buffers...
Sounds like the lines do not have category values associated to them (which is done automatically during import), so you probably need to run v.category, before running v.buffer.
On Wed, 05 Nov 2008 14:25:24 +0100
Moritz Lennert <mlennert@club.worldonline.be> wrote:
On 05/11/08 13:46, Otto Dassau wrote:
> Hi,
> boundary
> v.build quadsline
> 0 Flächen erstellt
> Lines buffers...
> 100%
> Areas buffers...
lines
import
yes, adding categories to the lines before v.buffer works..
2008/11/5 Moritz Lennert <mlennert@club.worldonline.be>:
is there any reason why v.buffer should ignore features without
category. At least warning should be printed out.
Or a flag to only use the features with category values...
At least it is documented in the man page:
"v.buffer creates a buffer around features of given type, which have a category in the given layer."
