Hello, I have some problems to install Grass 6.2 on my
Ubuntu 6.06.
I first tried the .deb package but there was a problem
of dependency not satisfiable with libc6. As it is
recommended not to change the version of libc6, I
switched to the source code.
I followed instructions given in the INSTALL file and on
the Wiki.
I first used:
CFLAGS="-g -Wall" sudo ./configure --with-cxx
--with-gdal=/usr/bin/gdal-config
--with-tcltk-includes=/usr/include/tcl8.4/
--with-postgres-includes=/usr/include/postgresql/
This works. And then
make
With "make" I get the following error messages:
First there are errors in almost all folders:
Errors in:
/media/sda7/proglinux/grass-6.2.0/lib/datetime
/media/sda7/proglinux/grass-6.2.0/lib/gis
/media/sda7/proglinux/grass-6.2.0/lib/gmath
/media/sda7/proglinux/grass-6.2.0/lib/linkm
/media/sda7/proglinux/grass-6.2.0/lib/driver
and so on all folders are listed
and finally:
make: *** [default] Erreur 1
If I try make install and then start grass, it don't
work of course.
Can someone help me?
Thank you,
Patrick Meyfroidt
University of Louvain, Belgium
Patrick, try to instal (via apt or something) the libgeos and
libgeos-dev packages, then run make again. Works for me.
Carlos
Ubuntu 6.06.
the Wiki.I first used:
--with-postgres-includes=/usr/include/postgresql/This works. And then
make
First there are errors in almost all folders:Errors in:
and so on all folders are listedand finally:
work of course.Can someone help me?
Thank you,
Patrick Meyfroidt
University of Louvain, Belgium_______________________________________________
grassuser mailing list
grassuser@grass.itc.it
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Ubuntu 6.06.
the Wiki.
some hints for compiling on debian based systems:
http://hamish.bowman.googlepages.com/debiangisfiles#compile
make
try:
cd /media/sda7/proglinux/grass-6.2.0/lib/datetime
make
and see what the error was (last few lines before it dies).
Hamish
