[GRASS-user] installation problems
Hello,
Sorry if the problem below is not exactly a grass problem, but I hope
this is the best place to find people who encountered it...
I currently work on Ubuntu Feisty, so when I compile a program from
sources I use the classical procedure :
./configure [options]
make
sudo checkinstall
Checkinstall usually works but sometimes does not...
Particularly with packages related to grass like gdal or Qgis.
Let's take the example of qgis-0.8.1 :
checkinstall
        first says the installation is successful,
        then create the debian package successfully,
        then fails at installing the .deb.
The problem is it tries to overwrite files belonging to grass in the
directory /usr/local/grass-6.3.cvs/include/grass !
So I tried to pass checkinstall with the option
--exclude=/usr/local/grass-6.3.cvs/include/grass
but lately a similar problem occurs with gdal files, and even cmake and
ccmake files in the end...
Any idea ?
Thanks, and a good week end to all !
Vincent
Vincent BAIN wrote:
Hello, Sorry if the problem below is not exactly a grass problem,
but I hope this is the best place to find people who encountered
it...
sources I use the classical procedure : ./configure [options]
What GRASS version?
make
sudo checkinstall
What checkinstall version? There are couple of bugs in the latest 1.6.1
[1], going to be fixed in the next release soon. But 1.6.0 has been
working fine for me with several software for months now, including
GDAL, GRASS and QGIS (until 0.81; in case of 0.9 there are issues
related to the new QGIS build system based on cmake, which I haven't
figured out how to handle with checkinstall 1.6.0 yet).
In case you are using 1.6.1, I recommend downgrading to 1.6.0 available
in Edgy repos, eg. here [2]. It should install fine on Feisty.
Checkinstall usually works but sometimes does not... Particularly
Let's take the example of qgis-0.8.1 : checkinstall first says the
installation is successful, then create the debian package
successfully, then fails at installing the .deb.
Here's my typical command line for building GRASS 6.3 deb for instance:
sudo checkinstall -D --pkgname=grass63 --pkgversion=`date +%F`
--install=no --strip=yes --stripso=yes
--pakdir=$HOME/src/checkinstall_pakdir --deldoc=yes --deldesc=yes
--delspec=yes --backup=no
sudo dpkg -i $HOME/src/checkinstall_pakdir/grass63_2007-07-18-1_i386.deb
Does that work?
and ccmake files in the end...
Any idea ?
Smells like checkinstall 1.6.1 issues. Try 1.6.0.
Maciek
[1]http://asic-linux.com.mx/~izto/checkinstall/index.php
[2]http://packages.ubuntu.com/edgy/admin/checkinstall
Well done Maciek, and thank you again !
Downgrading to 1.6.0 solves the problem.
Vincent
> it...
What GRASS version?
> make
> sudo checkinstall
Does that work?
> Any idea ?
Maciek
