[GRASS-user] installation problems
Hello,
I’m having trouble with installing grass in my directory. I would like to install grass locally as I don’t have root privileges. I’ve completed installing proj4 in a local area but cannot get grass to realize that it has been installed. when I run the configure script, I get the following message:
configure: error: *** Unable to locate External PROJ.4 includes.
any help would be appreciated :slight_smile:
thanks.
abhi
Abhinandan,
On Thu, Jun 26, 2008 at 2:00 PM, Abhinandan Raghavan
<abhinandan.raghavan@gmail.com> wrote:
Hello,
I'm having trouble with installing grass in my directory. I would like to
install grass locally as I don't have root privileges. I've completed
message:
you need to use these parameters of configure:
  --with-proj-includes=DIRS
  --with-proj-libs=DIRS External PROJ.4 library files are in DIRS
  --with-proj-share=DIR External PROJ.4 data files are in DIR
to indicate the directories.
Hint: I personally don't even install GRASS but run it from the
directory where I compiled. The start script is in bin.$ARCH, e.g.
./bin.x86_64-unknown-linux-gnu/grass64
Hope this helps
> message:
On Linux, you will also need to set LD_LIBRARY_PATH to include the
directory where the shared libraries are installed. Other platforms
have similar mechanisms (e.g. DYLD_LIBRARY_PATH on MacOSX).
Without that, modules which link against PROJ won't run, and linking
against libraries which themselves require PROJ (e.g. GDAL, and
various GRASS libraries) won't work either.
