[GRASS-user] installing add-ons for GRASS 6.4.2 on Ubuntu fails
I’ve never installed add-ons throught the WxPython GUI.
I need to use the v.mkhexgrid [1], but the process fails because at some stage (Rules.make) it tries to create/write into /usr/lib/bin folder (very strange).
Clearly there’s something wrong. I’ve read various past emails which report similar problems.
Questions:
  • how to fix it? I’ve tried the suggested patch from Hamish [2], but I can’t find the add-on in the GUI menus
  • is it possible to install an add-on manually? Does it require to pass the entire Make process?
I’ve installed GRASS from the ubuntugis lunchpad repositories.
giovanni
[1] http://svn.osgeo.org/grass/grass-addons/grass6/vector/v.mkhexgrid/
[2] http://osgeo-org.1560.x6.nabble.com/Problem-in-install-Extensions-from-addons-td5034042.html
Giovanni Allegri
http://about.me/giovanniallegri
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
On Mon, Apr 15, 2013 at 12:32 PM, G. Allegri <giohappy@gmail.com> wrote:
I've never installed add-ons throught the WxPython GUI.
strange).
You need (to wait for) current GRASS 6.4.svn or 6.4.3 which hopefully
addresses this problem.
The best would be that you compile 6.4.svn yourself on Ubuntu and
make a test before we release 6.4.3:
http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
thanks
I will go on compiling.
I’m not so expert in sw management on Linux, will it be problematic to have both a 6.4 and 7 GRASS on the same machine? I would like to test GRASS 7 too…
giovanni
2013/4/16 Markus Neteler <neteler@osgeo.org>
strange).
thanks
Giovanni Allegri
I’ve compiled GRASS 6.4.3RC2.
The add-on installation exits with the following error:
/usr/bin/install: impossibile eseguire stat di “/home/giova/
Data/GRASSDB/3003/PERMANENT/.tmp/xubuntu/16152.0/v.mkhexgrid
/man/man1/v.mkhexgrid.1”: File o directory non esistente
make: *** [install] Errore 1
WARNING: Installation failed, sorry. Please check above error messages.
In english it’s something like
/usr/bin/install: cannot execute stat “/home/giova/
/man/man1/v.mkhexgrid.1”: File or folder not existing
make: *** [install] Error 1
I’ve installed system wide with sudo, but I launch GRASS without sudoing. Could the problem be related to this?
giovanni
2013/4/16 G. Allegri <giohappy@gmail.com>
giovanni
strange).
thanks
Giovanni Allegri
Giovanni Allegri
