[GRASS-user] installing add-ons
I have no trouble downloading the add-ons I hope to use from the
repository, but could use some instruction on how to get them
installed/functional in a 6.2.2 installation (stock Ubuntu package).
Zack
are they C code addons or just SHELL scripts ?
Jachym
Zachary Parisa píše v So 08. 03. 2008 v 19:40 -0500:
Zack
grass-user mailing list
grass-user@lists.osgeo.org
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
The grass addon (if they are in C), can be installed by re-compiling the source code.
It may help this page: http://istgis.ist.supsi.ch:8090/pmwiki/index.php?n=GRASS.Installazione
Once compiled the grass source code, to add an addon module just extract the file in the grass source directory, cd to the module directory and run this command: INST_NOW=y make
Detailed informations for source compilation can be found at: http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_2/INSTALL
Bye,
Massimiliano
Zachary Parisa wrote:
Zack
Dr. Massimiliano Cannata
Environmental & Geomatic Engineer
Institute of Earth Scences - SUPSI
Trevano, C.P. 72, CH-6952 Canobbio, SWITZERLAND
Tel: +41 (0)58 / 666 62 14 Fax: +41 (0)58 / 666 62 09
E-mail: massimiliano.cannata@supsi.ch
Web: http://www.ist.supsi.ch
http://istgis.ist.supsi.ch:8001/geomatica/
The add-on I hope to install is i.topo.corr
When trying to install this (or any other add-on) either by " INST_NOW=y
make" or the "make MODULE_TOPDIR=$HOME/..." process as described below and
in the documentation
the process fails with:
Makefile:8: ../../include/Make/Module.make: No such file or directory
make: *** No rule to make target `../../include/Make/Module.make'. Stop.
I have tried with compiled versions 6.3 RC5 and RC6...but get the same
results.
Any ideas?
thanks,
Zack
source code.
Bye,
Massimiliano
Zack
Web:
View this message in context: http://www.nabble.com/installing-add-ons-tp15922472p16244490.html
results.
Any ideas?
You either need the full source code of GRASS (compiled or at least
configured) or need to use GEM - GRASS Extension Manager.
