[GRASS-user] "installing grass issue"
Appears to be that when i try to install grass from a .deb package it has a lot of dependencies, and ok i downloaded them but those decencies have more downloading have more and is like never ends.
Is there a way to install it with all the dependencies together?
since i used apt-get with this result:
juanchy:/home/criacuervo/Desktop# ls
grass_6.0.2-6_i386.deb libpq4_8.1.17-0etch1_i386.deb
libgdal1-1.3.2_1.3.2-4_i386.deb
juanchy:/home/criacuervo/Desktop# dpkg -i libgdal1-1.3.2_1.3.2-4_i386.deb
Selecting previously deselected package libgdal1-1.3.2.
dpkg: regarding libgdal1-1.3.2_1.3.2-4_i386.deb containing libgdal1-1.3.2:
libgdal1-1.5.0 conflicts with libgdal1-1.3.2
libgdal1-1.3.2 (version 1.3.2-4) is to be installed.
dpkg: error processing libgdal1-1.3.2_1.3.2-4_i386.deb (–install):
conflicting packages - not installing libgdal1-1.3.2
Errors were encountered while processing:
And i almost forget, i used Debian 5.0
this is a copy of my /etc/sources.list
deb cdrom:[Debian GNU/Linux 5.0.2 Lenny - Official i386 DVD Binary-1 20090628-15:08]/ lenny contrib main non-free
deb http://security.debian.org/ lenny/updates main contrib non-free
deb-src http://security.debian.org/ lenny/updates main contrib non-free
deb http://volatile.debian.org/debian-volatile/ lenny/volatile main contrib non-free
deb http://http.us.debian.org/debian/ lenny main
deb-src http://volatile.debian.org/debian-volatile/ lenny/volatile main contrib non-free
deb http://debian.gfoss.it/ lenny main
deb http://debian.unesr.edu.ve/debian/ lenny main
deb http://debian.ues.edu.sv/debian/ lenny main
i tried with qgis, and i installed it i thought, but was a pluging i think because when i try to open it this appears:
Error setting region (Problem with g.region?):
child process exited abnormally
and after that one this:
g.proj or projectionn error:ERROR:G_getenv():
Variable LOCATION_NAME not set
what i have to do?
All suggestion will be welcome!
thx,
Hello Juan Carlos,
yes, all packages have to be installed.
Im using OpenSuse and Im not a Debian expert. Maybe an Debian-user can
give you a hint how to install all these packages.
It seems, here you have a problem with two versions of gdal:
just instal one of them.
Achim
dpkg: error processing libgdal1-1.3.2_1.3.2-4_i386.deb (--install):
*And i almost forget, i used Debian 5.0*
deb cdrom:[Debian GNU/Linux 5.0.2 _Lenny_ - Official i386 DVD Binary-1
<http://volatile.debian.org/debian-volatile/lenny/volatile&gt; main
contrib non-free
contrib non-free
    > Error setting region (Problem with g.region?):
    > child process exited abnormally
    > and after that one this:
    > g.proj or projectionn error:ERROR:G_getenv():
    > Variable LOCATION_NAME not set
    > what i have to do?
    > All suggestion will be welcome!
    > thx,
grass-user mailing list
grass-user@lists.osgeo.org
is like never ends.
it gets there.
together?
try aptitude instead of apt-get, it has better conflict
resolution code.
ls
why do you have .debs downloaded manually? that shouldn't be
necessary. and 6.0.2 is far out of date, lenny shipped with
GRASS 6.2.3 and GDAL 1.5.2.
"aptitude install grass" should handle all that. there is no
need to run dpkg manually. in fact in most cases you shouldn't.
gdal 1.3.2 is from the old Debian/Etch, so it isn't surprising
that it is out of date WRT the rest of a modern Lenny system.
dpkg: regarding
libgdal1-1.3.2:
libgdal1-1.3.2
installed.
(--install):
libgdal1-1.3.2
processing:
try adding backports.org to your /etc/sources.list file.
there you will find a more modern package for DebGrass/Lenny:
http://packages.debian.org/grass
(and gdal too)
you should not have to handle anything at the .deb / dpkg level,
aptitude should be able to take care of all dependencies for
you, automatically.
Hamish
