I'm trying to install a GRASS7 from SVN into my home directory (I already
have 6.4.3 installed system wide), I'm following the guidelines at
http://trac.osgeo.org/grass/wiki/DownloadSource#GRASS7
http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Compile_from_source
However, on running 'make' I get the following error.
If anyone might recognize the likely source of the errors, I'd be grateful.
GRASS GIS 7.0.svn 56683 compilation log
Started compilation: Thu Jun 13 17:11:56 ICT 2013
Errors in:
/home/user/grass7/grass7_trunk/raster/r.external
/home/user/grass7/grass7_trunk/raster/r.in.gdal
/home/user/grass7/grass7_trunk/raster/r.out.gdal
/home/user/grass7/grass7_trunk/vector/v.out.ogr
/home/user/grass7/grass7_trunk/vector/v.in.ogr
/home/user/grass7/grass7_trunk/vector/v.external
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Thu Jun 13 17:12:59 ICT 2013
make: *** [default] Error 1
Running make in the following error directories gives:
~/grass7/grass7_trunk/raster/r.external
/grass7/grass7_trunk/dist.i686-pc-linux-gnu/lib/libgrass_vector.7.0.svn.so:
undefined reference to `OGR_G_GetGeometryType@GDAL_1.8'
*Configure appears to go without a hitch:*
CFLAGS="-g -Wall" LDFLAGS="-s" ./configure --prefix=/home/user/grass7
--with-png=yes --with-libtiff=internal --with-geotiff=internal
--with-jpeg=internal --with-gif=internal --with-ecw=yes --with-expat=yes
--with-sqlite3=yes --with-geos=yes --with-python --with-libz=internal
--with-netcdf --with-sqlite --with-threads=yes --without-grass
--without-ogdi --with-pg=/usr/bin/pg_config --with-xerces=yes
--with-freetype=yes --with-freetype-includes="/usr/include/freetype2/"
--with-pg=/usr/bin/pg_config --with-readline --with-ffmpeg=yes
--with-ffmpeg-includes="/usr/include/libavcodec /usr/include/libavformat
/usr/include/libavutil /usr/include/libswscale" --enable-largefile
--with-lapack --with-blas --with-postgres=yes
--with-postgres-includes=/usr/include/postgresql --with-mysql=no
--with-odbc=yes --with-python=yes --with-wxwidgets=/usr/bin/wx-config
--with-tcltk-includes=/usr/include/tcl8.5 --with-sqlite3=yes --with-cairo
--with-geos=/home/rcooper/grass7/bin
--with-gdal=/home/rcooper/grass7/bin/gdal-config --with-motif
--with-motif-includes=/usr/include
--with-proj-share=/home/rcooper/grass7/share/proj --with-cxx --enable-debug
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /home/user/grass7/grass7_trunk
Build directory: /home/user/grass7/grass7_trunk
Installation directory: ${prefix}/grass-7.0.svn
Startup script in directory:${exec_prefix}/bin
C compiler: gcc -g -Wall
C++ compiler: c++ -g -O2
Building shared libraries: yes
OpenGL platform: X11
MacOSX application: no
MacOSX architectures:
MacOSX SDK:
BLAS support: yes
C++ support: yes
Cairo support: yes
DWG support: no
FFMPEG support: yes
FFTW support: yes
FreeType support: yes
GDAL support: yes
NETCDF support: yes
GEOS support: yes
LAPACK support: yes
Large File support (LFS): yes
libLAS support: no
MySQL support: no
NLS support: no
ODBC support: yes
OGR support: yes
OpenCL support: no
OpenGL support: yes
OpenMP support: no
PNG support: yes
POSIX thread support: no
PostgreSQL support: yes
Readline support: yes
Regex support: yes
SQLite support: yes
TIFF support: yes
wxWidgets support: yes
X11 support: yes
View this message in context: http://osgeo-org.1560.x6.nabble.com/Installing-GRASS-on-Ubuntu-compilation-error-tp5059904.html
