hi maning, i haven't been playing so much with it (busy)
but i got grass7 svn work on jaunty
gdal and proj from synaptic
DEPENDENCIES
sudo apt-get install build-essential \
flex \
lesstif2-dev \
libfftw3-dev \
libglu1-mesa-dev \
libglu1-xorg-dev \
libpng12-dev \
libpq-dev \
unixodbc-dev \
doxygen \
libmysqlclient15-dev \
graphviz \
libcairo2-dev \
bison \
libncurses5-dev \
zlib1g-dev \
libjpeg62-dev \
libgdal1-dev \
libtiff4-dev \
libgcc1 \
tcl8.4-dev \
tk8.4-dev \
fftw3-dev \
libfreetype6-dev \
libavcodec-dev \
libxmu-dev \
libreadline5 \
libreadline5-dev \
python2.5-dev \
python-wxversion \
swig \
libwxbase2.8-0 \
libwxbase2.8-dbg \
libwxbase2.8-dev \
libwxgtk2.8-0 \
libwxgtk2.8-dbg \
libwxgtk2.8-dev \
python-wxgtk2.8 \
wx2.8-doc \
wx2.8-examples \
wx2.8-headers \
wx2.8-i18n \
python-numpy \
sqlite3 \
libsqlite3-dev \
python-opengl
svn checkout https://svn.osgeo.org/grass/grass/trunk grass_trunk
(wherever you want...i did it in /usr/local/src)
CFLAGS="-g -Wall" ./configure \
--with-gdal=/usr/local/bin \
-with-tcltk-includes=/usr/include/tcl8.4 \
--with-sqlite \
--with-cxx \
--with-fftw \
--with-freetype=yes \
--with-freetype-includes=/usr/include/freetype2 \
--with-readline \
--with-opengl-includes=/usr/include/GL \
--with-python=/usr/bin/python2.5-config \
--with-wxwidgets=/usr/bin/wx-config \
--enable-largefile=yes \
--with-proj-includes=/usr/include \
--with-proj-share=/usr/share/proj \
--with-proj-libs=/usr/lib
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /usr/local/src/grass_trunk
Build directory: /usr/local/src/grass_trunk
Installation directory: ${prefix}/grass-7.0.svn
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -Wall
C++ compiler: c++ -g -O2
Building shared libraries: yes
64bit support: no
OpenGL platform: X11
MacOSX application: no
NVIZ: yes
BLAS support: no
C++ support: yes
Cairo support: yes
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
GEOS support: no
JPEG support: yes
LAPACK support: no
Large File support (LFS): yes
MySQL support: no
NLS support: no
ODBC support: no
OGR support: yes
OpenGL support: yes
PNG support: yes
PostgreSQL support: no
Python support: yes
Readline support: yes
SQLite support: yes
Tcl/Tk support: yes
wxWidgets support: yes
TIFF support: yes
X11 support: yes
Regex support: yes
POSIX thread support: no
sudo make
Errors in:
No errors detected.
(hopefully :-))
sudo make install
this is what i did (indeed you can change parameters in ./configure)
....btw community, AM I RIGHT?...did i miss something or include to
much?
(suggestion appreciated)
another question:
what do i have to do exactly to update?
svn up
./configure (including the same parameters of the previous
installation?)
make
make install (again?)
..or there is another way to do it?
cheers,
mitch
On Thu, 2009-04-30 at 01:28 +0800, maning sambale wrote:
Compiling from source following:
http://grass.osgeo.org/wiki/Compile_and_Install#Ubuntu
I am somehow stuck here:
./configure --enable-gpl --enable-libvorbis --enable-libtheora \
--enable-liba52 --enable-libdc1394 --enable-libgsm \
--enable-libmp3lame --enable-libfaad --enable-libfaac \
--enable-libxvid --enable-pthreads --enable-libx264 \
--enable-shared
Unknown option "--enable-liba52".
See ./configure --help for available options.
ps.
in the GRASS dependencies:
I think "bpng12-dev" should be "libpng12-dev"
sudo apt-get install grass build-essential flex bison libncurses5-dev
zlib1g-dev \
libjpeg62-dev libgdal1-dev libtiff4-dev libgcc1 bpng12-dev tcl8.4-dev
tk8.4-dev fftw3-dev \
libfreetype6-dev libavcodec-dev libxmu-dev gdal-bin libreadline5
libreadline5-dev \
make python-dev python-wxversion swig
