I've done a quick search of the mailing list but haven't come across
anything: Has anyone been able to get a working installation on XP64?
It just so happens that this is the computer I need to get GRASS onto,
so I'd appreciate your thoughts on it. Specifically, I need to use the
3D Raster functions of the newer release.
The information contained in this email message is privileged
and confidential information intended only for the use of the
party named above. If the reader of this message is not the
intended recipient, you are hereby notified that any
dissemination, distribution or copying of this communication
is strictly prohibited. If you have received this communication
in error, please immediately notify us and delete the message
from your system. Thank-you.
Hi All,
I have only used on WindowsXP (32bit), that too the old GRASS6.1.
Am eagerly waiting for the release of the latest as a Setup.exe file.
Ravi Kumar
I’ve done a quick search of the mailing list but haven’t come across
so I’d appreciate your thoughts on it. Specifically, I need to use the
the 3D Raster functions of the newer release.
no idea if there are Win+64bit issues, but try it and see..
good luck,
Hamish
ps-
It is not appropriate to send legal disclaimers of this sort to a
public list.
X64 has a bug in it related to opening large files with 32 bit software. Worse yet, it is not very repeatable, but the bug crops up with programs like photoshop and open office calc. [Even CS3 isn't compiled for x64!) The problem is in gdi32.dll. I don't know if this will be a problem for GRASS, but I think it's likely to be.
That said, I really suggest installing suse 10.2 and just running grass in linux. It isn't very hard to compile. This way you will get real 64 bit performance. Probably not in memory space, but there are additional instructions used when running 64 bit code. Suse 10.2 will dual boot.
Hamish wrote:
Hi Everyone,
Hi Andrew,
good luck,
Hamish
ps-
public list.
I've been hearing about this large file bug in Windows, but I *routinely*
open files >> 10gb within RSI's ENVI, so I feel there is something else
going on here. Certainly there's a memory management issue due to the 32
bit memory calls, but that isn't the same as being able to read/write large
files. Most raster calculations need minimal memory anyway, since they are
most efficiently (memory-wise) done using tiled processing. GDAL's support
for large files under Windows has been sporadic, and my understanding was
that it had a lot to do with the cygwin environment and continuing LFS
issues with that.
I had a lot of success getting Debian linux running within a windows
environment using Virtual PC (which is now free !!!) and had flawless LFS
for GDAL (I was using it to run starspan).
--j
Hamish wrote:
Hi Everyone,
Hi Andrew,
good luck,
Hamish
ps-
public list.
Jonathan A. Greenberg, PhD
Postdoctoral Scholar
Center for Spatial Technologies and Remote Sensing (CSTARS)
University of California, Davis
One Shields Avenue
The Barn, Room 250N
Davis, CA 95616
Cell: 415-794-5043
AIM: jgrn307
MSN: jgrn307@hotmail.com
I should be clearer. Not every program under X64 has problems with large files. For instance, 7zip has a version compiled for x64 that can handle Gbytes. I also run sql. It is just the programs that use gdi32.dll.
I haven't had a gdi32 crash in about a month. The problem is a bugger to trace since it is not very consistent. One common thread is the programs crash at start up, presumably when requesting memory. I loaded the eval version of CS3 and had the same problem. [Don't even get me started on Adobe.]
I can't speak for virtual PC, but someone I know who used to work for VMware explained to me (and may I add it didn't sink in well since I'm not a programmer) that VPC and VMware cannot handle the "accelerated" features of fancy graphics cards. That is, you often need to turn off the hardware acceleration. This seems like a drawback to me for use with a graphical program.
All this said, I'm grateful for anyone writing opensource software and don't see the need to make their life any more difficult than need be. If the program requires linux, so be it. I have enough software running under linux that I can justify two PCs. Once you have samba installed, sharing files is easy. I haven't got aggressive enough to try to run GRASS via Xwindows on the PC, but if you don't like fooling with KVMs, that might be doable.
issues with that.
--j
Hamish wrote:
Hi Everyone,
Hi Andrew,
good luck,
Hamish
ps-
public list.
