This sounds OK too.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Thu, 17 Aug 2006 17:37:35 +0100 (BST)
To: Dylan Beaudette <dylan.beaudette@gmail.com>
Cc: <grassuser@grass.itc.it>, Glynn Clements <glynn@gclements.plus.com>
Subject: Re: [GRASS-user] integration of sample.c algorithms into r.resampleOn Thu, 17 Aug 2006, Dylan Beaudette wrote:
On 8/17/06, Paul Kelly <paul-grass@stjohnspoint.co.uk> wrote:
To throw in another suggestion, how about r.resamp.interp? This it would
mean it would be adjacent in the manuals to the other resampling modules
(r.resample and r.resamp.rst) for anyone looking for them, and might also
imply that r.resample (the only one with the full word in its name) was
kind of a default, basic resampler whilst r.resamp.interp and r.resamp.rst
used more advanced and/or interesting resampling methods.That sounds good to me.
Well I would commit it to CVS if it's OK. I briefly edited the r.bilinear
man page to create a rough manpage for r.resamp.interp (see below): are
there any glaring errors?Paul
r.resamp.interp(1) Grass User's Manual r.resamp.interp(1)
NAME
r.resamp.interp - Resamples raster map layers using
interpolation.SYNOPSIS
r.resamp.interpr.resamp.interp help
r.resamp.interp input=name output=name [method=string]
[--overwrite]Flags:
--overwriteParameters:
input=name
Name of input raster mapoutput=name
Name for output raster mapmethod=string
Interpolation method Options: nearest,bilinear,bicubic
Default: bilinearDESCRIPTION
r.resamp.interp fills a grid cell (raster) matrix with
interpolated values generated from a set of input layer
data points. A choice of three interpolation methods is
available; each uses the weighted values of a different
number of adjacent cells in the input map to determine the
value of each cell in the output map as follows:nearest neighbour (1 cell)
bilinear (4 cells)
bicubic (12 cells)
If there is a current working mask, it applies to the out
put raster file. Only those cells falling within the mask
will be assigned interpolated values. The procedure for
selection of input data will consider all input data rele
vant to interpolating values at the cell centers of the
current geographic region, ignoring the curent mask. Note
that for bilinear and bicubic interpolation, cells of the
output raster that cannot be bounded by the appropriate
number of input cell centers are set to null.NOTES
For longitude-latitude databases, the interpolation algo
rithm is based on degree fractions, not on the absolute
distances between cell centers. Any attempt to implement
the latter would violate the integrity of the interpola
tion method.SEE ALSO
g.region, r.resample, r.resamp.rstAUTHOR
Glynn ClementsLast changed: $Date: 2003/04/30 15:17:25 $
Full index
GRASS 6.3.cvs r.resamp.interp(1)
