[GRASS-user] Intergraph MGGA grid to Grass raster
Hello list,
I am using a GIS called MGE which has a module (called MGGA) that can export MGGA grids into Grass raster format. It produces the directories cats,cell,cellhd,cellmisc, and colr. Anyone know what I do with this?
Thanks in advance,
Bob
Bob Moskovitz
Seismic Hazard Zonation Project
California Geological Survey
http://www.conservation.ca.gov/cgs/shzp
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
Copy those to your mapset directory, inside the location directory?
I've always found it easier to export everything as GeoTif...
Daniel
On Jan 11, 2008 5:06 PM, Moskovitz, Bob
<Bob.Moskovitz@conservation.ca.gov> wrote:
Hello list,
Thanks in advance,
Bob
Bob Moskovitz
grass-user mailing list
grass-user@lists.osgeo.org
On Jan 11, 2008 8:06 PM, Moskovitz, Bob
Hello list,
Put them into a
location/mapset/
directory structure. However, the typical files from PERMANENT are also needed.
See page bottom of
http://download.osgeo.org/grass/grass6_progman/
for a diagram (rebuilding now, should be ok in 1h from now).
I put those files in a mapset, but when I try to display it, I get this:
   WARNING: can't get history information from [paloa_sg@PERMANENT]
   WARNING: can't read range file from [paloa_sg@PERMANENT]
   ERROR: Unable to read range file.
What should I do now?
Btw, it would be great if text was selectable in dialog boxes...then I won't have to type (just cut and paste) the error messages in this email :slight_smile:
-----Original Message-----
[mailto:neteler.osgeo@gmail.com]On Behalf
Of Markus Neteler
Sent: Friday, January 11, 2008 11:41 AM
To: Moskovitz, Bob
Cc: Grass-User (E-mail)
Subject: Re: [GRASS-user] Intergraph MGGA grid to Grass raster
> Hello list,
do with this?
Put them into a
location/mapset/
See page bottom of
