[GRASS-user] internal buffer of polygon
I tried using a negative values as
buffer=-3000 in v.buffer but it doesn't give me internal buffer in a
polygon layer.
Any hints?
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
Hi Maning,
Sometimes I have the same issue, but I don’t solve this on vector.
Just supose you have a map where 1 is your raster-based-polygon
and NULL is outside of polygon. You can use r.mapcalc to
invert it, in the maner that 1 come to be your non-polygon, and
NULL your polygon. So you can run r.buffer with positive value
and at the end may be you need to do some kind of crossing
between original and output maps.
Bests.
miltinho
2009/10/29 maning sambale <emmanuel.sambale@gmail.com>
buffer=-3000 in v.buffer but it doesn’t give me internal buffer in a
polygon layer.
Any hints?
cheers,
maning
“Freedom is still the most radical idea of all” -N.Branden
grass-user mailing list
grass-user@lists.osgeo.org
Milton:
Sometimes I have the same issue, but I don't solve
this on vector.
in the past I have created a negative vector mask with v.in.region (infinite
area as the inverse of a closed polygon is not really possible) and then run
'v.overlay op=not'.
but perhaps v.buffer + the original area fed to 'v.overlay op=and' does the
trick. ?
I can't quite remember the method I used, but it is possible using something like the above method.
Hamish
does anyone have a new(er) trick for negative vector buffers (in GRASS 7)?
thanks
On Thu, Oct 29, 2009 at 4:59 PM, Milton Cezar Ribeiro
<miltinho.astronauta@gmail.com> wrote:
Hi Maning,
Sometimes I have the same issue, but I don't solve this on vector.
Bests.
miltinho
polygon layer.
Any hints?
cheers,
maning
v.in.region + v.overlay to do the inversion.
H
--- On Thu, 4/19/12, Markus Neteler <neteler@osgeo.org> wrote:
Subject: Re: [GRASS-user] internal buffer of polygon
To: "Milton Cezar Ribeiro" <miltinho.astronauta@gmail.com>
Cc: "GRASS user list" <grass-user@lists.osgeo.org>
Date: Thursday, April 19, 2012, 9:17 AM
(in GRASS 7)?
thanks
wrote:
> Hi Maning,
on vector.
to
non-polygon, and
positive value
crossing
> Bests.
> miltinho
>> polygon layer.
>> Any hints?
>> cheers,
>> maning
-N.Branden
>> _______________________________________________
On Thu, Apr 19, 2012 at 6:17 PM, Markus Neteler <neteler@osgeo.org> wrote:
Internal buffers of areas are now (r51573) supported in trunk with
negative distances if GEOS support is enabled, i.e. v.buffer
distance=-1000 type=area works.
Markus M
thanks
Hi Maning,
Bests.
miltinho
polygon layer.
Any hints?
cheers,
maning
2012/4/29 Markus Metz <markus.metz.giswork@googlemail.com>:
cool, thanks! Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
On Sun, Apr 29, 2012 at 7:11 PM, Markus Metz
Markus M
I tried, phantastic! thanks so much,
