I have a set of rasters (ground acceleration, modal mag., and distance) that I want to interpolate based on the location of my point features (borehole location) and update my point feature with the values from this interpolation. I see that v.what.rast might help, but I’m not sure what kind of interpolation it uses (probably nearest neighbor?). I also see that v.sample can be used, but it does not work with geographic coordinate system locations. So, I was hoping that the list might have other ideas in solving my problem.
Thanks in advance!
Bob
Robert Moskovitz
California Geological Survey
Seismic Hazards Zonation Program
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
might help, but I'm not sure what kind of interpolation it uses
I think it is best to approach the problem in two steps. First
do your interpolations using a method appropriate to your data type,
sampling density, sensitivity to outliers, etc.
Then once you have your interpolated surface run v.what.rast, or
v.rast.stats, or from addons v.rast.stats2 or v.what.rast.buffer
depending if you want to pick off the exact interpolated value
at a given site, a statistical indicator for values around that
site (e.g. variance) as either a buffer distance or within a
given vector polygon.
By the way, we are currently discussing / upgrading the v.krige
offerings, you're most welcome to weigh in on the conversation
if that's what you're after.
