[GRASS-user] Interpolation on a Grid
List,
I'd like to do an interpolation of xyz data points that I have, and put the interpolated data on 100' x 100' grid. So that each 100' x 100' square has an associated elevation value. Any suggestions as to how best to do this?
Frank Aragona
to do this?
depending on how many input points you have either:
  v.in.ascii, g.region res=100, v.surf.rst
or for massive datasets (>1-3 million points):
  g.region res=100, r.in.xyz, r.to.vect, v.surf.rst
choice of method and {r|v}.surf.* interpolation module are subject to
nature of data & personal preference. see also r.surf.nnbathy in wiki addons. the modules' manual pages should help you decide.
Hamish
Unable to achieve desired result. I has nice contour maps using
following commands:
v.in.ascii -z z=3 --overwrite input=survey.txt output=fieldData
v.build map=fieldData
g.region vect=fieldData
v.surf.rst input=fieldData layer=0 elev=DTM1
r.contour input=DTM1 output=contourVec1 step=100 cut=0
r.contour input=DTM1 output=contourVec2 step=20 cut=0
d.mon x0
d.rast map=DTM1
d.vect map=contourVec1 display=shape,zcoor
d.vect map=contourVec2 display=shape
But to have elevation on grid could not figure out parameters for
v.surf.rst command. In GUI could not find input option.
Can you help me by giving complete commands with options and values as
per above example to have shown elevation at regular grid. I started
with resolution of 1 for a size of 100x100, and for grid I can have
resolution of 20.
Using GRASS 6.4.0RC5 on Ubuntu 9.10
Mine data is small.
Thanks in advance.
H.S.Rai
following commands:
d.mon x0
d.rast map=DTM1
Here's an example that I've used (copied from r.info). The original point layer is more or less a grid of points at 40X40 meter separation.
v.surf.rst input="eyv_pts" layer=0 elev="eyv_dem" tension=40. segmax=40 npmin=300 dmin=2.500000 dmax=12.500000 zmult=1.0
HTH,
Micha
resolution of 20.
Mine data is small.
Thanks in advance.
Micha Silver
http://www.surfaces.co.il/
Arava Development Co. +972-52-3665918
