[GRASS-user] invalid temporal topology
when playing with temporal framework I discovered that my dataset has
invalid temporal topology:
$ t.topology modis | grep valid
| Temporal topology is: ...... invalid
How can I discover the reason, why it's invalid? Thanks in advance, Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
2014-04-22 20:28 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
OK, solved - missing time in timestamps, anyway the module should
print to the user reason of invalidity...
Martin
Hi Martin,
you can inspect the temporal topology using "g.gui.timeline" or you
pipe the output of "t.topology -m input=STDS" into a file and search
for the temporal relationships that should not occur in a valid
temporal topology (only precedes, follows, before, and after are valid
relations). All temporal relationships that occur in a STDS are
counted and shown by "t.topology input=STDS".
Best regards
Soeren
2014-04-22 21:21 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
Martin
grass-user mailing list
grass-user@lists.osgeo.org
