[GRASS-user] Is it possible to export a Raster to KML
Greetings
I have a raster mapthat I want to create an overlay in a KML file. Is it possible to do this with GRASS? if not, as anyone as an alternative to use?
Thanks
Kat
Hi Katrin,
Yes, it’s possible using the r.out.kml add-on, see [1][2]
[1] http://grass.osgeo.org/wiki/GRASS_AddOns#r.out.kml
[2] http://osgeo-org.1803224.n2.nabble.com/KML-generator-for-GRASS-6-4-td4548193.html
Daniel.
On Mon, Oct 24, 2011 at 1:40 PM, katrin eggert <katrineggert1980@gmail.com> wrote:
Greetings
Thanks
Kat
grass-user mailing list
grass-user@lists.osgeo.org
Hello Daniel
By reading the r.out.kml manual I have a few questions:
1- "KML expects data to be in Latitude-Longitude using the WGS84 datum and EGM96 vertical datum. ". My data is in WGS84 UTM 26N. Does this mean that I have to create a new location with this information or it is ok to use a Location in this Geofraphic projection/coordinates system?
THanks
Kat
2011/10/24 daniel mcinerney <daniel.o.mcinerney@gmail.com>
Hi Katrin,
Daniel.
Greetings
Thanks
Kat
On Tue, Oct 25, 2011 at 6:32 PM, katrin eggert
Hello Daniel
(see also
http://en.wikipedia.org/wiki/Keyhole_Markup_Language#Geodetic_reference_systems_in_KML
Yes. you have to reproject the maps.
Hi
Maybe it would be better to explain that in manual entry. Just one more question: what is the EPSG code for that projection?
Thanks
Kat
2011/10/26 Markus Neteler <neteler@osgeo.org>
Hello Daniel
(see also
katrin eggert wrote:
Hi
http://www.google.com/search?q=google+kml+epsg
-> 4326
Thanks
Kat
> Hello Daniel
> and
(see also
Hi
Thanks for all the feedbacks
I have used it and It’s ok but…
THe results are not much different if I use my data in WGS84UTM and reprojecting to EPSG:4326. Just a slightly difference. Is this expectable such a slightyly difference? (I’m not an expert in Geo Reference Systems)
Thanks
2011/10/26 Markus Metz <markus.metz.giswork@googlemail.com>
Hi
→ 4326
Thanks
Kat
Hello Daniel
and
(see also
On Wed, Oct 26, 2011 at 11:35 AM, Markus Metz
Hi
-> 4326
Note that KML expects data to be in Latitude-Longitude using
the WGS84 datum and EGM96 vertical datum as the manual
says. This is not exactly EPSG:4326.
I have added a map with geoid undulations in Trentino, Italy
here:
http://grass.osgeo.org/wiki/Global_datasets#EGM2008_Geoid_Data
Hi
I’m Sorry but I’m lost in this…
So the email that you sent and those links in google point to use EPSG:4326 but the script requires a different one ? That doesn’t make any sense…
If I define a Location with that geoid map that you sent me, will I have what? EPSG:4326 or the one used by r.out.kml?
Thanks
Kat
→ 4326
here:
Hi
I'm Sorry but I'm lost in this...
but the script requires a >different one ? That doesn't make any sense...
what? EPSG:4326 or the one used >by r.out.kml?
Thanks
Kat
   > -> 4326
see also here:
http://www.gdal.org/ogr/drv_kml.html
as far as i understand the ogc-kml-manual
(http://www.opengeospatial.org/standards/kml , => 2.2.0 OGC KML), the
Latitude-Longitude are in EPSG:4326, but measuring the height/elevation in
google earth is in EGM96 vertical datum and not in EPSG:4326.
in my experience overlaying kml (vector and raster) with EPSG:4326 in google
earth works relatively well in flat areas, in mountain areas there are
sometime distortions therefore.
HTH
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Is-it-possible-to-export-a-Raster-to-KML-tp6924758p6939523.html
I can confirm this from my (limited) experience to export data
to KML. To correct for the geoid heights, you could use the previously
indicated map and calculate the local ellipsoid-geoid difference
and vertically shift your vector data with v.transform. Then export
to KML. For raster, use r.mapcalc to shift.
google
for some additional information
see http://www.epsg-registry.org/ => retrieve by code:
EPSG: 4326 => GeodeticCRS (geographic 2D) [WGS 84] => 2D
EPSG: 4978 => GeodeticCRS (geocentric) [WGS 84] => 3D
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Is-it-possible-to-export-a-Raster-to-KML-tp6924758p6939578.html
> areas there are
Markus:
data to KML. To correct for the geoid heights, you could use
the previously indicated map and calculate the local
ellipsoid-geoid difference and vertically shift your vector
Then export to KML. For raster, use r.mapcalc to shift.
n.b., IIUC raster KML support in google earth is essentially a
hack building on/abusing their raster-icon support.
they may have improved things, but this is what I was lead to
believe at the time of writing r.out.kml.
probably it is useful to consider if the ellipsoid-geoid
difference is important vs. the overall vertical differences
in the data, if the result is just for viewing maybe it is not
worth the trouble.
Hamish
I find this thread interesting. In my experience overlaying both raster (orthophoto) and vector data in Google Earth with KML, EPSG:4326 has worked with no problems whatsoever. So far as I know, GE does not apply a vertical datum, it simply drapes the 2D data over its internal terrain model.
Would it be possible for you to share some data where you have seen that this is a problem?
Roger
areas there are
Markus:
worth the trouble.
Hamish
Roger is correct. GE will just drape your raster data over it’s terrain mesh regardless of what vertical parameters your data has. It is essentially 2D with a z value and is interpreted as such. That is why EPSG:4326 works, because GE doesn’t care about any other information. No conversions/shifts occur.
I export rasters from GRASS, generate hillshades, and overlay in GE using gdal2tiles daily. I seldom see any alignment issues, and when I do it is usually my data. Of course there are alignment issues in GE, but they will vary place to place regardless of topography.
  • Jamie
Roger
areas there are
Markus:
worth the trouble.
Hamish
On Sat, Oct 29, 2011 at 12:08 AM, Jamie Adams <jaadfoo@gmail.com> wrote:
Roger is correct. GE will just drape your raster data over it's terrain
EPSG:4326 works, because GE doesn't care about any other information. No
I had such problems in the past with 3D buildings which where flying
over the ground... the data where in the Alps.
