[GRASS-user] is it possible to import map without providing datum &Projection..????(Urgent!!)
Hi !!
is it possible to import map without providing datum &Projection…???
and does datum wgs84 and lcc can co-exist at display.
Thanks & Regards
Kunal Malik
09871147561
There is a location setup option for plain old X,Y coordinates, that are an undefined system.
Mark
On Tue, Apr 15, 2008 at 7:34 AM, Kunal Malik <kunal.malik81@gmail.com> wrote:
Hi !!
Thanks & Regards
Kunal Malik
09871147561
grass-user mailing list
grass-user@lists.osgeo.org
Please elaborate …
Mark
Hi !!
Thanks & Regards
Kunal Malik
09871147561
Thanks & Regards
Kunal Malik
09871147561
If you dont want to deal with projections you can create a location that is x,y based, without a projection.
If you have know what projection the data is in, and you have the appropriate location setup, then you can use the -o (override) parameter to import regardless of the imported data’s projection file or conflict stated upon import.
Mark
On Tue, Apr 15, 2008 at 8:09 AM, Kunal Malik <kunal.malik81@gmail.com> wrote:
Please elaborate …
Mark
Hi !!
Thanks & Regards
Kunal Malik
09871147561
Thanks & Regards
Kunal Malik
09871147561
