I'm figuring out how to install GRASS 7 on my Mac (OS 10.8.3). According to
the instructions here:
http://grass.osgeo.org/grass70/source/snapshot/INSTALL
GDAL should be compiled without GRASS support. I recently installed GDAL
using Kyngesburye's binary, as prerequisite to installing GRASS 6. My
question is, do I need to install another version of GDAL prior to
installing GRASS 7, and if so then are there issues with having multiple
versions installed?
Gregory
View this message in context: http://osgeo-org.1560.n6.nabble.com/Is-Kyngesburye-s-binary-for-Mac-GDAL-compatible-with-GRASS-7-tp5042848.html
My GDAL is good for any GRASS that is built to use it, as long as you match the GDAL major version specified.
versions installed?
Gregory
grass-user mailing list
grass-user@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
Thanks, William. Would you please explain what you meant when you wrote, ". .
. as long as you match the GDAL major version specified"? Is that a
parameter that I have to set in the compilation process? I'm new to this and
apologize if the question is terribly naive.
Gregory
View this message in context: http://osgeo-org.1560.n6.nabble.com/Is-Kyngesburye-s-binary-for-Mac-GDAL-compatible-with-GRASS-7-tp5042848p5042978.html
If you are installing binaries, there is no compilation involved by you. I meant if Barton's GRASS says my GDAL 1.9.2 (the current version), and I package a GDAL 1.9.3, that will also work, but a GDAL 1.10 will not.
Gregory
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
