Dear all,
I intend to mosaic two 24 bit images in LAT LON location.
I imported a 24 bit coloured PNG image in Grass using r.in.gdal in an x-y location.
GRASS treated it as a combination of three 8 bit images, one for red, one for green,
and one for blue and imported them as three separate maps.
After going through the archives, I tried to use r.patch to combine all the three components.
The output of which wasn’t a 24bit image but was only one of the components. (Not coloured)
d.rgb module does display a coloured 24 bit image after inputing the three components to it.
I geocoded them to get non-coloured 8 bit geocoded images in the target location.
I did the same for the second 24 bit image.
Mosaicing works fine(i.image.mosaic), but i need to use 8 bit images(24 bit images converted to 8 bit images prior to importing, using xv; resolution weak)
or any one of the 8 bit components of a 24 bit image.
Is there a way to mosaic 24 bit images and to output it as a single 24 bit image?
Regards
Nagesh
www.nio.org
www.indian-ocean.org
www.reefindia.org
www.coastalhazards.info
www.mangroveindia.org
