Hi All,
Is watershed image segmentation program or a similar module available in GRASS GIS?
I understand that we have r.watershed, i.segment and r.grow in GRASS GIS. But I do not know which one best suits my problem.
The problem is:
I have two layers of raster data -
1.) a gradient image (obtained by applying a 3 x 3 sobel filter on a water index using r.mapcalc), and
2.) a seed image of 2 classes labelled as “1” and “2” and remaining pixels as “0”.
I want to use the seed image and the gradient image (which shows direction of change in intensity) information to perform segmentation using the watershed algorithm and label all “0” pixels as either 1 or 2.
r.watershed does not use watershed segmentation algorithm. i.segment is something close but I am not sure.
Please suggest.
Any comment is appreciated.
Uttam.
On 11/11/15 07:47, Uttam Kumar wrote:
Hi All,
GRASS GIS?
The problem is:
2.) a seed image of 2 classes labelled as "1" and "2" and remaining
pixels as "0".
using the watershed algorithm and label all "0" pixels as either 1 or 2.
Please suggest.
Currently GRASS GIS only proposes a region-growing segmentation algorithm in i.segment.
However, even though it is not really made for this, and I'm not sure of the exact algorithm used in r.watershed, this module can be used for image segmentation. One caveat are the edges which r.watershed treats in a particular manner, but I'm sure a work-around is possible.
Moritz
Hi there…
I used r.grow to segment dNBR images to map wildfires. See:
https://www.researchgate.net/publication/269692754_Semi-automated_mapping_of_burned_areas_in_semi-arid_ecosystems_using_MODIS_time-series_imagery
Hope it helps…
(attachments)
2015-11-11 3:47 GMT-03:00 Uttam Kumar <uttamsinha09@gmail.com>:
Hi All,
The problem is:
Please suggest.
Uttam.
grass-user mailing list
grass-user@lists.osgeo.org
Dr. Leonardo A. Hardtke
Laboratorio de Teledetección y S.I.G.
Centro Nacional Patagónico (CONICET)
Bvd. Brown 2825, 9120
Puerto Madryn, Chubut, Argentina
Hi Leonardo,
I went through the paper “Semi-automated_mapping_of_burned_areas_in_semi-arid_ecosystems_using_MODIS_time-series_imagery” and I am also trying to do something similar except that I want to separate water bodies.
Is it possible for you to share the GRASS code on segmentation (based on Pratt, W.K., 2001. Digital Image Processing. NY: Wiley-Interscience, New York, pp. 491–556.) which you executed as an ad hoc function in r.mapcalc.
Appreciate any help.
Uttam.
On Wed, Nov 11, 2015 at 8:48 AM, Leonardo Hardtke <leohardtke@gmail.com> wrote:
Hi there…
Hope it helps…
Hi All,
The problem is:
Please suggest.
Uttam.
