I'm facing an issue when trying to install the addon r.zonal.classes. When executing "g.extension -l" the addon is well listed as available, but when I try to install it using "g.extension r.zonal.classes", g.extension say it don't find it:
Fetching <r.zonal.classes> from GRASS GIS Addons repository (be patient)...
ERROR: Extension <r.zonal.classes> not found
What grass version are you using? and which operating system? Does the same happen with other add-ons?
In my Fedora box, it goes fine, but there was a problem with grass76 in windows that started when we migrated to github. AFAIK, this was solved in grass78. So, if you have an old grass, please update
HTH,
Vero
El jue., 30 ene. 2020 a las 7:18, Taïs (<tgrippa@ulb.ac.be>) escribió:
I’m facing an issue when trying to install the addon r.zonal.classes.
When executing “g.extension -l” the addon is well listed as available,
but when I try to install it using “g.extension r.zonal.classes”,
g.extension say it don’t find it:
Fetching <r.zonal.classes> from GRASS GIS Addons repository (be patient)…
Indeed, you are right. After upgrading to 7.8 it works perfectly !!
Thanks a lot
Le 30/01/20 à 12:46, Veronica Andreo a écrit :
Hi Tais,
HTH,
Vero
