Due to an earlier issue with i.landsat.toar, I upgraded to the most recent version of GRASS available (found here): http://wingrass.fsv.cvut.cz/grass64/. I was previously using the latest Stable build (here: http://grass.osgeo.org/grass64/binary/mswindows/native/). I am running Windows 7, 64 bit.
When I try to run certain functions, I get errors related to DLLs. For example, a Windows error pops up when I try to import or export a raster (r.in.gdal and r.out.gdal through the GUI). The import window will appear once I click OK to the error, and if I go to use the Import function again, I do not get the error again during that session.
However, the export function is not working at all. I get a couple of errors that pop up in Windows:
- The procedure entry point H5Eauto_is_V2 could not be loacted in the dynamic lik library hdf5dll.dll
- The procedure entry point GTIFFreeMemory could not be located in the dynamic link library gdal19.dll
In case this helps, I’ve pasted what appears in the Command Console when I simply try to open GRASS and use the GUI to navigate to Export Common Raster Formats at the end of the e-mail
Errors also appear in the black-background Command Window along the lines of this:ERROR 1: Can’t load requested DLL: C:\Python27\Lns\gdal_HDF5Image.dll
127: The specified procedure could not be found.
I tried to install an SVN build of GRASS 7 earlier in the week, and had similar error messages come up.
Should I just try to use the Stable version of GRASS for now? Or am I probably doing something incorrectly on the install?
I’m still new to GRASS, and I realize I might be better to run it on a Linux boot (or at least in a Virtual Machine?), but I won’t have time to learn more about that right now.
Thank you again for any help!
Best regards,
Mike
Text from the Command Console:
File “C:\Program Files (x86)\GRASS GIS
6.4.3svn\etc\wxpython\lmgr\frame.py”, line 557, in OnMenuCmd
GUI(parent = self).ParseCommand(cmd)
6.4.3svn\etc\wxpython\gui_core\forms.py”, line 1867, in
ParseCommand
blackList = _blackList)
6.4.3svn\etc\python\grass\script\task.py”, line 470, in
parse_interface
tree = etree.fromstring(get_interface_description(name))
6.4.3svn\Python27\lib\xml\etree\ElementTree.py”, line 1283,
in XML
return parser.close()
6.4.3svn\Python27\lib\xml\etree\ElementTree.py”, line 1636,
in close
self._raiseerror(v)
6.4.3svn\Python27\lib\xml\etree\ElementTree.py”, line 1488,
in _raiseerror
raise err
xml.etree.ElementTree
ParseError
unclosed token: line 243, column 1
