Hello all,
I am evaluating grass. Can i use grass in a j2ee web application deployed to an
application server. ie.. Can it be used similar to esri gis server that will
hand you a url of the map to display in a jsp??
Thanks in advance
ken
Ken wrote:
Hello all,
Thanks in advance
ken
Theoretically, maybe. GRASS is an analysis package though, rendering
maps for web display is best done by something meant for that like
mapserver, geoserver, mapnik, featureserver, etc.
For serving maps from datasets I recommend you look at those options. If
you want to run some grass tools based on user input and show the
results you would setup a workflow of web interface->grass->map
service->web display.
You may also consider using libgeos in java to perform spatial
operations on your data and return you objects that can be displayed
with the above mentioned tools or you're own custom graphic widget.
Alex
the analytical part is possible through PyWPS (python) [1] or 52North
WPS (java)[2]
for the display part, PyWMS [3] can be used
jachym
[1] http://pywps.wald.intevation.org
[2] http://52north.org/maven/project-sites/wps/52n-wps-site/
[3] http:/pywms.wald.intevation.org
Ken píše v Ne 01. 03. 2009 v 01:38 +0000:
Hello all,
Thanks in advance
ken_______________________________________________
grass-user mailing list
grass-user@lists.osgeo.org
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
