Two source DEMs each cover half the project analytical area. I want to
join the two into a single raster DEM. Tried using 'r.mapcalc dem_proj =
dem2 + dem3' but that did not produce anything visible. From reading
mapcalc.pdf and mapcalc-algebra.pdf I know the module is designed for
combining multiple raster maps cell-by-cell. I've not found how to
edge-match and join two rasters that do not have overlapping coverage.
Please pass me a pointer to the appropriate module to use for this
operation.
join the two into a single raster DEM. Tried using ‘r.mapcalc dem_proj =
dem2 + dem3’ but that did not produce anything visible. From reading
I think that the '+'operator honors NULL cells, so anywhere that is NULL in either raster will be null in the result. That’s not what you want in this case.
combining multiple raster maps cell-by-cell. I’ve not found how to
operation.
r.patch does this.
As per the man page, be sure to set the region to all input rasters in advance:
g.region rast=dem2,dem3
Micha Silver
GIS Consultant, Arava Development Co.
[http://www.surfaces.co.il](http://www.surfaces.co.il)
