Although I'm not a geographer, having looked at a globe I do know about
longitude meridians running through the poles.
If you only had two longitude values you wouldn't even be able to calculate
EW distance because of this effect. But if you know both the value for
latitude and longitude at each of say two points, you know how close each is
to the equator and so should be able to correct for the effect, doing some
kind of great circle route type calculation. Or...
Jerry
-----Original Message-----
From: Nikos Alexandris [mailto:nikos.alexandris@felis.uni-freiburg.de]
Sent: Thursday, December 13, 2007 2:27 PM
To: Patton, Eric
Cc: Gerald Nelson; Michael Misun; grass-user@lists.osgeo.org
Subject: RE: [GRASS-user] (kein Betreff)
Just another piece of information (although don't remember where I read
it): In general every 0.0001° of latitude equals ~ 11m. Longitude I
think is the tough one...
On Thu, 2007-12-13 at 14:12 -0500, Patton, Eric wrote:
The width of a degree of longitude varies by latitude; meridians of
longitude converge to
a single point at the poles. Latitude varies as well, although
considerably less so, due to
the rotation of the earth slightly squashing the poles, and bulging the
Equator.
~ Eric.
From: grass-user-bounces@lists.osgeo.org on behalf of Gerald Nelson
Sent: Thu 12/13/2007 3:06 PM
To: 'Nikos Alexandris'; 'Michael Misun'
Cc: grass-user@lists.osgeo.org
I'm curious about the statement that "Lat-Long is not good to do distance
measurements" Someone else made a similar observation in a different
conversation recently too. I'm not a geographer so I'm probably missing
something but doesn't lat long just give you a point on the surface of the
earth and if you have two of these don't you more or less automatically
know
the distance between them?
Regards, Jerry
[mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Nikos Alexandris
Sent: Thursday, December 13, 2007 10:55 AM
To: Michael Misun
Subject: Re: [GRASS-user] (kein Betreff)
Lat-Long is not good to do distance measurements!
Why don't you reproject your lines in a "metric" projection system and
check the distances again.
On Thu, 2007-12-13 at 14:03 +0100, Michael Misun wrote:
> hello everybody!
> i have a little problem:
> i want to set vertices on lines in a specified space (e.g. 2 km) in a
lat
long coordinate system.
> i tried it with "v.to.points -vi .... dmax=0.03" and it works. the
problem
is, that in the equatorial zone the space between the new added points is
about 1,7 km but up to the polzones the spacing is rather smaller and
about
600 m!
> can anybody help me with this problem? a want to have an equal space for
all vertices on my polylines
> michael
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University
Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype:
Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
