Dear all,
I have installed Grass 7 on Ubuntu 14.04.
I am trying to access to repository http://svn.osgeo.org/grass/grass-addons/grass7/ it but unfortunately i received this error massage that I posted entirely.
Unable to load extensions. Traceback (most recent call last):
File “/usr/lib/grass70/scripts/g.extension”, line 1084, in
version = grass.version()[‘version’].split(‘.’)
KeyError: ‘version’
Someone could help me?
Thanks
Carmine
On Wed, Jun 25, 2014 at 11:23 AM, Carmine Massarelli <
carmine.massarelli@ba.irsa.cnr.it> wrote:
Dear all,
*Unable to load extensions. Traceback (most recent call last):*
*File "/usr/lib/grass70/scripts/g.extension", line 1084, in <module>*
*version = grass.version()['version'].split('.')*
*KeyError: 'version'*
How did you installed GRASS 7? There is some long term issue in GRASS from
repositories and g.version command. Try to run there two commands in the
terminal:
g.gisenv set=DEBUG=5
g.version -rge
and post the output here.
The older discussion is here:
[GRASS-user] g.extension
http://lists.osgeo.org/pipermail/grass-user/2014-January/069703.html
I would be glad if somebody else from the developers would look at this
issue because I'm not sure how to proceeded because I'm not getting the
error.
The workaround is to compile GRASS yourself. It is not so difficult,
although it might be challenging for the first time.
GRASS Wiki: Compile and Install Ubuntu
http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
[GRASS-dev] Updates of wiki page for compiling on Ubuntu
http://lists.osgeo.org/pipermail/grass-dev/2014-June/069334.html
http://lists.osgeo.org/pipermail/grass-dev/2014-June/069371.html
[GRASS-dev] G7: OGSF compilation error on Ubuntu 14.04
http://lists.osgeo.org/pipermail/grass-dev/2014-June/069704.html
Write here if you will have problems with this.
Vaclav
Thanks
Carmine
grass-user mailing list
grass-user@lists.osgeo.org
Carmine, thanks for the message. I'm sending it to the list, it will be
more useful there.
At the end, I actually created a ticket and suggested a patch [1].
If you tried the compilation, let us know if it worked.
Vaclav
[1] http://trac.osgeo.org/grass/ticket/2351
On Wed, Jun 25, 2014 at 12:13 PM, Carmine Massarelli <
Dear all,
I installed it with grass70-core
There is some long term issue in GRASS from repositories and g.version
command. Try to run there two commands in the terminal:
bash: /usr/lib/grass70/etc/prompt.py: File o directory non esistente
g.version -rge
D2/5: G_file_name(): path =
/media/massarelli/sdb/Mappe/GRASS/Puglia_Landsat_nord/PERMANENT
version=7.0.0svn
date=2014
revision=
build_date=2014-06-24
build_platform=x86_64-pc-linux-gnu
Errore di segmentazione (core dump creato)
