[GRASS-user] kml file reading on grass:
i want to read kml files using grass62
is it possible…then what is the command to read kml files using grass…
pls helpme…
bharath.s
is it possible....then what is the command to read kml files using
grass.....
pls helpme....
You can use v.in.ogr for this *if* your OGR installation has been compiled with
libexpat support. See also
http://www.gdal.org/ogr/drv_kml.html
for details.
