Hello,
I'm using OSX 10.4.8 on a G5 system. I downloaded and installed "All
Frameworks" package and the GRASS 6.2.1-2 application. These are
dated January 21. Before I installed the frameworks packages, I
removed the old ones I had (by dragging them to the trash). BTW, I
installed the old frameworks for a previous version of QGIS, not
grass.
When I start GRASS.app, gis.m does not start, but I get a command
line. I cannot run any commands because it appears to need an older
version of the GDAL framework. Here's an example:
Mapset <Imagery> in Location <SnakeSpawning>
GRASS 6.2.1 > g.list rast
dyld: Library not loaded: /Library/Frameworks/GDAL.framework/Versions/1.3/GDAL
Referenced from: /Applications/GRASS/GRASS.app/Contents/Resources/bin/g.list
Reason: image not found
Trace/BPT trap
The GDAL framework I installed appears to be 1.4:
GRASS 6.2.1 > ls /Library/Frameworks/GDAL.framework/Versions/
total 4
0 ./ 0 ../ 0 1.4/ 4 Current@
Any help would be appreciated.
Thank you.
Bill
Bill Perkins
Pacific Northwest National Laboratory
Environmental Technologies Division, Hydrology Group
P.O. Box 999 MSIN K9-36
Richland, Washington, USA 99352
voice: (509) 372-6131 fax: (509) 372-6089 email: william.perkins@pnl.gov
