Hi everyone,
Have you run into this kind of errors:
GRASS 6.3.0 (Romania):~> i.landsat.rgb red=RGB321.3@marius
green=RGB321.2@marius blue=RGB321.1@marius
Processing
Hi everyone,
Processing
Nope.
red=RGB321.3@marius green=RGB321.2@marius blue=RGB321.1@marius
Processing ...
Segmentation fault
ERROR: bad rule (syntax error): white
Processing ...
Segmentation fault
Processing ...
Segmentation fault
ERROR: bad rule (syntax error): whiteIt's a three band Landsat mosaic. I am running Ubuntu
8.04 with GRASS 6.3 from Jachym Cepicky's repo
(http://les-ejk.cz/ubuntu/). I am not
really sure where to start poking.
It would seem that r.univar is failing in this part of the i.landsat.rgb script:
for i in $RED $GREEN $BLUE ; do
g.message "Processing <$i> ..."
MIN=`r.univar -ge $i perc=2 | grep "^percentile_" | cut -d'=' -f2`
MAX=`r.univar -ge $i perc=$BRIGHTNESS | grep "^percentile_" | cut -d'=' -f2`
g.message -d message="<$i>: min=$MIN max=$MAX"
r.colors $i col=rules << EOF
0% black
$MIN black
$MAX white
100% white
EOF
done
so $MAX would be unset, and r.colors gets a color without a value, which is a bad rule.
can you try "r.univar -ge RGB321.3@marius perc=98" on the command line and see what happens?
also, what does "g.region -p" look like?
and finally can you rerun i.landsat.rgb with debug messages turned on?
g.gisenv set="DEBUG=1" # to turn them back off set to 0
then the g.message info will be displayed.
but why does r.colors not complain about "$MIN black" too?
Hamish
