[GRASS-user] Landsat Stack import and export
Greetings
I've a Landsat image with 6 bands in Tif format. I need to import into grass, do some processing and export the same band in a Stack.
The import is easy using r.in.gdal but my difficulty is to export 6 bands in one single file. Is it possible using GRASS?
Thanks
Best regards,
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5093 (20100506) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
2010/5/7 António Rocha <antonio.rocha@deimos.com.pt>:
Greetings
To my knowledge no.
But you can export it separately, then merge with GDAL tools. See
http://gfoss.blogspot.com/2008/06/gdal-raster-data-tips-and-tricks.html
-> Merge various map/bands into a RGB composite
(should work for more bands than 3).
2010/5/7 Markus Neteler <neteler@osgeo.org>:
Greetings
To my knowledge no.
Sure it is. Create a group in GRASS, export the group (r.out.gdal
input=<group_name>) to a file format that supports multiple bands,
e.g. GeoTIFF.
Markus M
Greetings
Regarding the possibility of exporting an GROUp, using r.in.gldal, the groups are not listed in that menu. So the user cannot see the available groups.
It's still processing but IO have one question: The processing bar restarted at least 3 times, what is happening? Because it file, now, it seems that it's not "growing". Is it doing some file-check or something?
Thanks
Antonio
Greetings
To my knowledge no.
e.g. GeoTIFF.
Markus M
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5094 (20100507) __________
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5100 (20100510) __________
http://www.eset.com
2010/5/10 António Rocha <antonio.rocha@deimos.com.pt>:
Greetings
r.out.gdal you mean?
groups.
g.list type=group
will list all groups
If you export a group, each raster map is exported separately, even if
they all end up in one file. If you use r.out.gdal --verbose, there
would be several messages like
Exporting raster map <raster_name> (band <number>)...
and for each, the progress bar starts anew.
Depending on the grass version you are using, there might be some
checks first to prevent potential data loss (latest 6.4+).
Note that r.out.gdal uses the current computational region (resolution
and extends) for export.
Markus M
Greetings
bands in
To my knowledge no.
e.g. GeoTIFF.
Markus M
http://www.eset.com
http://www.eset.com
