John wrote:
g.region -p
rows: 14000
cols: 11000
cells: 154000000
for type = float this will use 154000000 * 4 / 1024000 ~= 600mb
RAM for method = min. (floats are 4 bytes each) It will be
twice that for mean. so memory and the percent= option are not
an issue here. (memory use is dependent on the region rows x
columns, not the number of input points)
2.1Gb file
r.in.xyz -s -g input=/home/bob2/rawdata/clean/test4.asc
output=test4 method=min type=FCELL fs=, x=6 y=7 z=8 zscale=1.0
percent=100
Unable to open input file </home/bob2/rawdata/clean/test4.asc>
So anything above 2Gb fails, even using percent=25, which for > the 2.1Gb file should have had an effect if memory was an
issue.
as Glynn explained, I was wrong- glibc's fopen() does care if it
is not used on a fully 64bit software stack.
if you have a 32bit machine, the solution/workaround for this is
to pipe from stdin instead. try this:
cat /home/bob2/rawdata/clean/test4.asc | r.in.xyz input=- \
output=test4 method=min fs=, x=6 y=7 z=8
or this:
r.in.xyz input=- output=test4 method=min fs=, x=6 y=7 z=8 < \
It does not really use the memory (or swap file) when using
'-s' flag.
right, the scan flag only has to remember a single set of
min/max values for x,y,z. that's just a few bytes. if it sees
a smaller/larger value it can forget the old one and just
remember the current leader.
Memory hangs around 45%, swap file=0% but the CPU hits 100%
varying between processors (watched in system monitor).
If '-s' flag is removed to create a raster then it uses 100%
of memory
of, then you should employ the percent= option until it does
not. (start with percent=50 to make it run in 2 passes)
and <2Gb files start to process fine (didn't continue
processing, to save time in testing), but >2Gb give the same
message: 'Unable to open input file...'
try sending the data via stdin rather than reading the file
directly, as in the examples above.
This 32bit machine only has 1Gb RAM (the 64bit machine has
2Gb RAM and never had a problem), but (as observed in system
monitor) I don't think memory is an issue for scanning the
data with the '-s' flag.
right, as scanning doesn't have to remember much at all.
I compiled and installed yesterday (20/03/10) following the
specific Ubuntu page, but added yes to largefile support (and
ignored the slight typo over folder locations, 'grass_current
/ grass_trunk'.)
you mean the wiki page?
... so changing to "input=-" should make it work on the 32bit
machine.
regards,
Hamish
