[GRASS-user] Large vector files
I wanted to get some feedback on how well GRASS works with very large vector
files (> 2gb) -- I have a 64 bit mac that I have grass running on now, so
I'm hoping the 64 bit memory system will work -- thoughts?
--j
Jonathan A. Greenberg, PhD
NRC Research Associate
NASA Ames Research Center
MS 242-4
Moffett Field, CA 94035-1000
Office: 650-604-5896
Cell: 415-794-5043
AIM: jgrn307
MSN: jgrn307@hotmail.com
vector files (> 2gb) -- I have a 64 bit mac that I have grass running on
now, so I'm hoping the 64 bit memory system will work -- thoughts?
--j
Hi Jonathan,
did you enable large file support ?
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Hmm, I am using the binaries from
http://www.kyngchaos.com/software/unixport/grass/ --> assuming LFS was
enabled (I can always recompile if I need to), are there large file issues
with *vectors* I need to worry about? The raster LFS is fine, mind you --
I'm very happy with that. I'm just a bit fed up with ArcMap's 2gb
limitation on file sizes, and I'm wondering if GRASS has ESRI beat in vector
LFS along with the raster LFS...
--j
--j
Hi Jonathan,
MS 242-4
Cell: 415-794-5043
AIM: jgrn307
Good point. I am not entirely sure. I do know that there can be problems with
the topology library when files get extremely large: see past messages about
lidar data and r.in.xyz .
Hamish might have some good input on this....
Dylan
vector LFS along with the raster LFS...
--j
>> --j
> Hi Jonathan,
> Cheers,
Dylan Beaudette
530.754.7341
