[GRASS-user] Layer management window questions
   Two questions about working in the layer management window using 7.3.svn:
   1.) When re-arranging the z-order of map layers why must only a lower
level map be moved up and not also an upper level map moved down?
   2.) When a workspace is saved with a specific set of maps and one map in
the set is changed, how can I save this new set with a different name? I
tried to use the down-arrow icon to save the altered map set and the dialog
box asked if I wanted to overwrite the existing workspace. When I clicked
the 'no' button I was not offered the opportunity to enter a new workspace
name because the dialog box closed.
TIA,
Rich
dialog box asked if I wanted to overwrite the existing workspace. When I
clicked the 'no' button I was not offered the opportunity to enter a new
workspace name because the dialog box closed.
   Answered: File -> Workspace -> Save as ...
Rich
On Fri, Oct 7, 2016 at 10:41 AM, Rich Shepard <rshepard@appl-ecosys.com>
I think this is wxPython limitation. You can try it in the "wxPython demo"
and report it as bug at wxPython/wxWidgets bug tracker.
Vaclav,
   OK, that makes sense.
Rich
