[GRASS-user] Learning to use vector layers
Hi Daniel,
Well, it depends on your database structure. If you have one table for each month:
SELECT t1.id, t1.east, t1.north, t1.rain,t2.rain,t3.rain FROM table1 as t1, table2 as t2, table3 as t3 WHERE…
Jaime
----- Mensaje original ----
De: Daniel Victoria daniel.victoria@gmail.com
Para: Jaime Carrera jaicarrerahdez@yahoo.com
CC: grass grassuser@grass.itc.it
Enviado: lunes, 26 de marzo, 2007 16:36:23
Asunto: Re: [GRASS-user] Learning to use vector layers
Yea, that could do it also, just have to figure out how to perform
different queries for each column so I’d have average January on col
1 and avg February on two and so on. Probably a bunch of table
updates?
Thanks
Daniel
On 3/26/07, Jaime Carrera jaicarrerahdez@yahoo.com wrote:
Hi Daniel,
You could also generate a table like this:
id|easting|northing|9001|9002|9003|…|9012|9101|…
Then you have your data in one table which can be
linked to the vector file. Such a table can be
generated from other tables using SQL commands.
HTH
Jaime
— Daniel Victoria daniel.victoria@gmail.com
escribió:
I have a vector problem and I think it might be a
job for vector layers.
I have a postgresql table with daily meteorological
station data (~10
years, 300 stations) and I’d like to get average
monthly precipitation
for each station.
That I can easily do with a SQL query, generating a
view and attaching
the view to a vector file where the CAT column is
the station number.
The problem is, I can only attach one SQL view at a
time since the
vector file has only one category (from what I read,
it’s one category
per layer connection correct?)
So, I though about some options:
  1. either generate 1 vector file for each month -
    simple but then I
    don’t learn about layers
  2. keep changing the database connection for each
    month - works but
    seems kind of improvisation
  3. Use layers, one layer for each month. I’d have
    the advantage of not
    having categories for stations with no data for a
    specific month for
    example and also, I’d learn about layers
So, the proper questions:
Does this sounds like a job for vector layers?
How do I add categories to a vector file but, the
categories should
come from a column in a SQL view? From what I read,
v.category can
only add sequential cats and I’d like the cats to be
the station
number.
Cheers and sorry for the long email
Daniel
grassuser mailing list
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
Regístrate ya - http://correo.espanol.yahoo.com/
Correo Yahoo!
Hi Jaime,
No, all data, for all stations and all months/days are in one big
table! I guess I'll just keep changing the network connection for now.
Daniel
On 3/26/07, Jaime Carrera <jaicarrerahdez@yahoo.com> wrote:
Hi Daniel,
month:
table2 as t2, table3 as t3 WHERE...
Jaime
De: Daniel Victoria <daniel.victoria@gmail.com>
Para: Jaime Carrera <jaicarrerahdez@yahoo.com>
CC: grass <grassuser@grass.itc.it>
different queries for each column so I'd have average January on col
updates?
Thanks
Daniel
> Hi Daniel,
> id|easting|northing|9001|9002|9003|...|9012|9101|...
> HTH
> Jaime
> --- Daniel Victoria <daniel.victoria@gmail.com>
> escribió:
> > Hi all,
> > station data (~10
> > years, 300 stations) and I'd like to get average
> > for each station.
> > view and attaching
> > the station number.
> > time since the
> > it's one category
> > 1) either generate 1 vector file for each month -
> > simple but then I
> > don't learn about layers
> > 2) keep changing the database connection for each
> > month - works but
> > 3) Use layers, one layer for each month. I'd have
> > specific month for
> > example and also, I'd learn about layers
> > categories should
> > v.category can
> > only add sequential cats and I'd like the cats to be
> > the station
> > number.
> > Daniel
> > _______________________________________________
> __________________________________________________
> Correo Yahoo!
Correo Yahoo!
