[GRASS-user] Legend with multiple columns - scale
Hi everyone,
I am new to the world of Grass and have run into a bit of a snag. I am currently trying to create a legend with multiple columns (3). I can place the legend on my map without difficulties, however the problem arises when I try and move it. Based on the map in question, I want the legend displayed on the left hand side of my map. As I alter the legend's x location (where /x/ /y/) to bring the legend closer to the left edge of the map, the spacing between the columns increases substantially (i.e. the legend seems to be maintaining a link to the right edge of the map and is just increasing the spacing between the columns so that the left edge of the legend matches the /where x /position). The problem with this is that it is not graphically appealing whatsoever.
Is there anyway that I can specify the width of the column itself so that the spacing is reduced? Or is there any way that I can remove that "link" with the right hand edge of the map so the legend moves freely along the x axis without being stretched out?
Also with regards to my scalebar. Is there any way that I can change the text of the scalebar so that the units are in km instead of metres? Right now I am using a map at a scale of 1:500 000, and I would rather my scalebar display 100 km as opposed to 100 000 metres.
Any suggestions would be greatly appreciated.
There is don't-go-off-the-edge code in there as you suspect. (see
ps/ps.map/ps_vlegend.c) Can you file a wish/bug in the tracker
for that? preferably with an example from the spearfish or North
Carolina test datasets + screenshots of the issue.
for now you can play with the paper margins; but is it the paper margin
or the map-box margin which is the limit?
this has recently been added in grass 6.4, you'll need to compile from
a SVN snapshot to get it. see the online ps.map help page for details.
Hamish
