Hello list!
I tried to compile today's grass6.1:
`./configure --with-cxx --with-postgres-libs=/usr/local/pgsql/lib \
--with-postgres-includes=/usr/local/pgsql/include`
leads to:
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
FORTRAN compiler:
Building shared libraries: yes
64bit support: no
NVIZ: yes
BLAS support: no
C++ support: yes
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: no
GDAL support: yes
GLw support: no
JPEG support: yes
LAPACK support: no
Large File Support (LFS): no
Motif support: no
MySQL support: no
NLS support: no
ODBC support: no
OGR support: yes
OpenGL(R) support: yes
PNG support: yes
PostgreSQL support: yes
Readline support: no
SQLite support: no
Tcl/Tk support: yes
TIFF support: yes
X11 support: yes
... which looks OK to me.
When I run `make`, it gives errors in most directories.
Descending to one of them and running `make` there results in the following error:
make: *** No rule to make target `/home/fkindl/svnrepos/grass6/dist.i686-pc-linux-gnu/lib/libgrass_vect.so', needed by `/home/fkindl/svnrepos/grass6/dist.i686-pc-linux-gnu/bin/v.what'. Stop.
libgrass_vect.so has not been built! - any ideas why that is?
grass6.0.2 sources build OK on the same machine.
yours,
\Flo.
Florian Kindl
Institut für Geographie
Universität Innsbruck
