[GRASS-user] library problem with i.landsat.toar
Hi list,
I wanted to install the i.landsat.toar - addon, following the instruction in the README-file (make MODULE_TOPDIR=$HOME/grass64/),
I also made "./configure" before and also "make lib", which says "Nothing to do for target »lib«"!
The procedure works fine for other addons (e.g. i.landsat.dehaze, v.what.rast.buffer and others),
but when I try to start the i.landsat.toar addon, it says "Incompatible library version for module".
I recompiled grass, but this didn't help.
I'm using grass6.4 on Ubuntu 8.10.
Thanks for any help,
Christine
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger01
was grass already built, or are you adding to a packaged binary version?
target »lib«"!
that should be "make libs" not "make lib"
you might have to remove any other version of grass to keep it from
getting confused (generally this isn't needed, but may help if the
local system has gotten mixed up).
another way if you fully build grass from source is to copy the
i.landsat.toar/ directory into the imagery/ dir in the main grass source
code, and after grass has built cd imagery/i.landsat.toar/ and run "make"
with no arguments.
Hamish
-------- Original-Nachricht --------
Datum: Wed, 18 Feb 2009 16:01:29 -0800 (PST)
Von: Hamish <hamish_b@yahoo.com>
An: grass-user@lists.osgeo.org, Christine Sandmeier <christine.sandmeier@gmx.de>
Betreff: Re: [GRASS-user] library problem with i.landsat.toar
grass was already built before.
> target »lib«"!
I tried it with "make libs", instead of "make lib", but this doesn't help (maybe this should be changed in the README-file of the grass-addons).
I already removed all other versions of grass - this didn't help.
with no arguments.
I also tried this before and did it again now. This works fine for other addons, but didn't help for i.landsat.toar.
any other ideas?
Jetzt 1 Monat kostenlos! GMX FreeDSL - Telefonanschluss + DSL
für nur 17,95 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K11308T4569a
