I've just downloaded the current Grass 6.2 (compiler produces grass63 as the
executable). I also have updated GDAL and PROJ. Grass configures without
problems and compiles with a single warning of an error in .../proj. I'm
running SuSE 10.1 on an intel based system with a GB of RAM.
Running grass63 resuls in the following message when starting:
"g.region: error while loading shared libraries: libgdal.so.1: cannot open
shared object file: No such file or directory"
libgdal.so.1 exists as an alias for libgdal.so.1.10.0 in /usr/local/lib, so
evidently g.region is looking in the wrong.
I'ld to know how to fix this.
JWDougherty
the executable). I also have updated GDAL and PROJ. Grass configures
without problems and compiles with a single warning of an error in
.../proj. I'm running SuSE 10.1 on an intel based system with a GB of RAM.
JWDougherty
You can try to add the path of gdal to /etc/ld.so.conf and run ldconfig after
in root.
Y.
Yves Jacolin
http://yjacolin.gloobe.org
> RAM.
> open shared object file: No such file or directory"
> so evidently g.region is looking in the wrong.
> Thanks,
> JWDougherty
after in root.
Y.
Yves,
Thanks for the ideas. The path was already in /etc/ld.so.con. The cure was
running ldconfig. Thank you again.
John
