[GRASS-user] lidar data - nnbathy x bspline
I did some Lidar interpolation with nnbathy and bspline. data has
~16.5mill points, and final dem has ~35mill cells.
while nnbathy did some very nice results (see image), it took ~8hours
to interpolate. bspline is beautifully fast, did the job in ~1hour,
but the final dem has many artifacts.
I was wondering how to avoid these artifacts with bspline? or with we
could have a vector version of nnbathy?
Carlos
http://www.igc.usp.br/pessoais/guano/temp/lidar_bspline.jpg
http://www.igc.usp.br/pessoais/guano/temp/lidar_nnbathy.jpg
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Hi Carlos and all,
Carlos
The ugly things in the outer regions are due to the interpolation method. I can do nothing. The other artifacts correspond to a badly overlapping between regions. I have more "homeworks" than I expected :-S
I beg your pardon for all these problems and errors. Although the old bspline versions worked nicely, the grass6.x version is quite young (it is available since the end of July) because I rewrote almost everything except the interpolation functions. In the other hand, it was not really tested till now, just when you all began to use it. I know, those are not valid excuses, sorry.
Roberto.
Hi Carlos and all,
Carlos
I was working on it and I've just update cvs. Now interpolation with v.surf.bspline should works quite nice.
Roberto.
Roberto Antolín Sánchez
Politecnico di Milano – Polo Regionale di Como
(Laboratorio di Geomatica V2.8)
Via Valleggio, 11 – 22100 Como, Italy
tel: +39 031 332 7533 || fax: +39 031 332 7519 email: roberto.antolin@polimi.it
Ciao Roberto.
Nice work with v.surf.bspline! I ran some tests, this time no
artifacts were produced in the sub-regions limits. Alsdo it is very
fast!
I'd just like to poin some issues:
- You could add, in the output messages, a indication of how many
sub-regions will be used, so the user knows approximately how much of
the interpolation has been done, how much still left.
- I tried to use the --overwrite option, but it didn't work.
- I did a test on an area 3.2x0.9 km, with 1m resolution, and it
worked fine. When I changed the resolution to 0.25m, I got an error
msg:
GRASS_INFO_ERROR(12405,3): Interpolation: The region resolution is
too high: 46080000.000000 cells. Consider to change it.
It worked with a resolution of 0.33m, but the resultant surface were
with a "pixelated" look, I don't know if is a problem with bspline or
GRASS dealing with non-round values for UTM regions.
That's all for now. If I find anything more, I'll let you know
Carlos
On 1/15/07, Roberto Antolin <roberto@geomatica.como.polimi.it> wrote:
Hi Carlos and all,
> Carlos
Roberto.
_________________
Hi Carlos and all,
Ciao Roberto.
fast!
Yes, you are right! I've already thought it. I'll see what I can do.
Just a question, what do you think about the output messages? Are they a lot or are they usefull?
msg:
Due to allocation memory problems I have to constrain the number of total cell.
I have to try to resolve this. Anyway, do you really need a 3km^2 DTM with such a resolution? :wink:
Could you give us a link as you did with bspline.jpg and nnbathy.jpg, please?
That was a lot! Thank you very much for your help!!
Another last question, are these immages above the commands output maps or are they aspect raster maps?
Roberto.
Roberto
I guess they could be reduced. Maybe the user is more interested in
knowing how many sub-regions will be used and in which one the process
is than what are the exact boundaries of the sub-regions.
total cell.
I am trying to recreate a DEM some Italian researchers made, and they
used a 0.33m resolution. I tried 0.25m just to see what would happen.
please?
Sure. here they are:
Vesuvius Volcano, 2.5m resolution (you can see that there are still
some artifacts)
http://www.igc.usp.br/pessoais/guano/temp/bspline_2007.jpg
Details:
1m resolution
http://www.igc.usp.br/pessoais/guano/temp/bspline_1m.jpg
0.33m resolution
http://www.igc.usp.br/pessoais/guano/temp/bspline_033m.jpg
They are shaded relief maps.
Regards
Carlos
_________________
Hi Carlos and all,
some artifacts)
Is this dataset available? I would like to do some test too. Although, those are intrinsic features to the interpolation method (dividing the whole zone into smaller regions) and shaded relief maps (as aspect maps), I'm afraid, I was wondering whether they could be reduced.
If this is not possible, I'll try to give you a better explanation about why they are produced.
Roberto.
> msg:
the current limit is 30000000 /* about 5500x5500 cells */
in vector/lidar/v.surf.bspline/main.c
total cell.
You should let the GRASS libgis memory allocation functions worry about
that, not impose arbitrary limits in a module. Some people have access
to huge computers with lots of resources; or put another way, what is a
massive amount of memory today might be common 3-5 years from now.
At minimum consider changing the G_fatal_error() to a G_warning().
regards,
Hamish
