I find that after running each of the v.lidar.* the resulting vector lacks topology, so I can't view the categories:
i.e. (after v.lidar.correct):
GRASS 6.4.2RC1 (ITM):~/GIS/DEM/LIDAR_EinYahav > v.category south_correct opt=report
ERROR: Unable to open vector map <south_correct@EinYahav_LIDAR> on level 2.
Try to rebuild vector topology by v.build.
So I run v.build, and then I get the vector with 4 different layers, each with a different number of cat values (different max category).
Is this what is supposed to happen? Should I add a v.build step between each of the v.lidar.* stages?
Micha
opt=report
Oops. v.category should not really need topology.
The v.lidar.* tools (as well as the v.surf.* tools) are supposed to
work with massive point data for which topology is not needed. Most
vector modules do require topology, however, so if you want to use
those, you need to build topology, but I would not do that by default
for point data.
Markus M
Micha
grass-user mailing list
grass-user@lists.osgeo.org
On Sun, Dec 18, 2011 at 12:12 PM, Markus Metz
opt=report
For the record: MarkusM has fixed this in trunk in
http://trac.osgeo.org/grass/changeset/49959
