[GRASS-user] Line_Height to db attribute
I have a series of vector contour maps imported from CAD files. The CAD lines were digitized in 3d so the lines were set at the proper height, and I imported them with v.in.dxf. The z values now come in as Line_height values:
east, north: 586205.150707, 4261840.15315
map28@PERMANENT:
  Type: Line
  Length: 1005.435416
  Line_height: 160.0
  Layer: 1
  Category: 120
  Driver: sqlite
  Database: /Users/nick/Documents/Grass/sardis/PERMANENT/dbf/sardisutm.rsd
  Table: map28_con10
  Key_column: cat
  Attributes:
    cat: 120
    layer: CON10
    entity: LWPOLYLINE
    handle: 3E1
I’m sure there’s an easy way to get those Line_Height values into proper z coordinates, but I cannot figure out how to do it. Any help would be greatly appreciated!
Many thanks,
Nick Cahill
values:
map28@PERMANENT:
  Type: Line
  Length: 1005.435416
  Line_height: 160.0
  Layer: 1
  Category: 120
  Driver: sqlite
  Table: map28_con10
  Key_column: cat
  Attributes:
    cat: 120
    layer: CON10
    entity: LWPOLYLINE
    handle: 3E1
Why do you think the vector doesn't have proper z coordinates? Line_height
160 means that the vector feature actually has z coordinates, otherwise it
wouldn't show Line_height item at all. If you want to display it in 3D
mode, there is an option to switch between draping on surface and
displaying it as truly 3D
Anna
Many thanks,
Nick Cahill
grass-user mailing list
grass-user@lists.osgeo.org
Aaaah! I hadn’t seen that option in the new Grass 7. Apologies!
Best wishes,
Nick Cahill
map28@PERMANENT:
Type: Line
Length: 1005.435416
Line_height: 160.0
Layer: 1
Category: 120
Driver: sqlite
Table: map28_con10
Key_column: cat
Attributes:
cat: 120
layer: CON10
entity: LWPOLYLINE
handle: 3E1
Why do you think the vector doesn’t have proper z coordinates? Line_height 160 means that the vector feature actually has z coordinates, otherwise it wouldn’t show Line_height item at all. If you want to display it in 3D mode, there is an option to switch between draping on surface and displaying it as truly 3D
Anna
Many thanks,
Nick Cahill
If you see any need to improve the documentation, please suggest!
