Hi GRASSers,
I have a line vector representing survey transects, and I need to split it
into segments based on elevation (say, 100 m height difference). After
scavenging the list archives and some googling I'm trying to do like that
generate contours from a DEM (r.contour)
generate a 10 m buffer along each transect line (v.buffer)
clip contours with the buffer (v.overlay)
merge transects with clipped contours (v.patch)
get intersections (v.clean tool=break err=intersections)
put intersections into ASCII format (v.out ascii intersections)
pipe intersections to v.segment
Anyway, it seems quite a long way... maybe I'm wrong!
Anyone has hints/suggestions?
Any circuit design must contain at least one part which is obsolete, two parts
which are unobtainable, and three parts which are still under development.
Damiano G. Preatoni, PhD
Unità di Analisi e Gestione delle Risorse Ambientali
Dipartimento Ambiente-Salute-Sicurezza
Università degli Studi dell'Insubria
Via J.H. Dunant, 3 - 21100 Varese (ITALY)
tel +39 0332421538
fax +39 0332421446
http://biocenosi.dipbsf.uninsubria.it/
ICQ: 78690321
jabber: prea@jabber.org
skype: prea.net
Please consider the environment before printing this email
Per favore non mandatemi allegati in formati proprietari
Please do not send attachments in proprietary formats
(Word, Excel, PowerPoint, etc.)
Meglio usare formati standaridzzati e documentati
Better use standard open formats
(.odt, .txt, .html, .pdf, .shp, dump SQL)
http://www.gnu.org/philosophy/no-word-attachments.html
Standard UNI CEI ISO/IEC 26300:2007
O< ascii ribbon campaign - stop html mail - http://www.asciiribbon.org
