[GRASS-user] line thickness
hello
How can I make a vector line thicker on display (d.vect ???)
regards
Ahmet Temiz
Jeoloji Müh.
Afet Ýþleri Genel Müdürlüðü
Deprem Araþtýrma Dairesi
Tel: (312) 287 89 51 veya (312) 287 26 80/1547
Faks: (312) 287 89 51
E. Posta: temiz@deprem.gov.tr
www.deprem.gov.tr
Ahmet Temiz
Geological Eng.
General Directorate of Disaster Affairs
Earthquake Research Department
Phone: +90 (312) 287 89 51 or (312) 287 26 80/1547
Fax: +90 (312) 287 89 51
E. Mail: temiz@deprem.gov.tr
www.deprem.gov.tr
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
orkun temiz@deprem.gov.tr wrote:
hello
In the display manager (D.M) just see all that U can achieve, includes thickenning vector lines too.
regards
Ahmet Temiz
Jeoloji Müh.
www.deprem.gov.tr
Ahmet Temiz
Geological Eng.
www.deprem.gov.tr
grassuser mailing list
grassuser@grass.itc.it
Yahoo! Messenger with Voice. PC-to-Phone calls for ridiculously low rates.
*/orkun <temiz@deprem.gov.tr>/* wrote:
    hello
d.vect comes with a width= parameter to handle line width.
       width Line width
> hello
       width Line width
I wonder how hard it would be to implement line thickness based on an
attribute .... ?
just a thought.
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
> > hello
> width Line width
> Markus
attribute .... ?
I just added this feature to CVS, so could you please test if it's working for
you? There are two new options: wcol= and wscale=. Let's say you have a column
"channel_width" and its values are in meters.
d.vect map=streams width=2 wcol=channel_width wscale=0.05
means that line widths are 0.05 * channel_width and if this value is negative,
the default width (2) will be used. Please note that the line width column
should be either INTEGER or DOUBLE PRECISION type.
Huidae Cho
just a thought.
Dylan Beaudette
530.754.7341
> > > hello
> > width Line width
> > Markus
> attribute .... ?
for you? There are two new options: wcol= and wscale=. Let's say you have
a column "channel_width" and its values are in meters.
negative, the default width (2) will be used. Please note that the line
width column should be either INTEGER or DOUBLE PRECISION type.
Huidae Cho
Huidae:
Wow! that was fast.
Looks like it works quite well. Thanks!
here is the output:
http://169.237.35.250/~dylan/temp/d.vect-wcol-test.png
Dylan Beaudette
530.754.7341
This could be done in a script. It is already implemented in
d.vect.thematic.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Reply-To: <dylan.beaudette@gmail.com>
Date: Tue, 16 May 2006 10:17:51 -0700
To: <grassuser@grass.itc.it>
Subject: Re: [GRASS-user] line thickness
    hello
       width Line width
attribute .... ?
just a thought.
Dylan Beaudette
530.754.7341
> > > > hello
> > > width Line width
> > > Markus
> > attribute .... ?
> working for you? There are two new options: wcol= and wscale=. Let's say
> you have a column "channel_width" and its values are in meters.
> Huidae Cho
Huidae:
Wow! that was fast.
here is the output:
Yikes... after updating from CVS yesterday (after the line thickness patch) it
looks like vector polygons are not being drawn via d.vect:
getting segmentation faults when type=area !!
Any thoughts on that?
Dylan Beaudette
530.754.7341
Sorry, I fixed it.
Huidae Cho
> > > > > hello
> > > > width Line width
> > > > Markus
> > > attribute .... ?
> > Huidae Cho
> Huidae:
> Wow! that was fast.
> here is the output:
> Cheers,
Dylan Beaudette
530.754.7341
